View Full Version : 86 Elcamino with LS3 Engine need feed back on oval Exhaust!!
Rwolf15241
05-28-2014, 03:21 PM
86 Elcamino with LS3 Engine need feed back on oval Exhaust!!I'm rebuilding the Elco, looking at a Oval exhaust for ground clearance!!
thanks RW
andrewb70
05-28-2014, 04:47 PM
thanks RW
How low will the car sit? It sounds like you are over complicating things. A 2.5" exhaust is perfectly adequate for a LS3 and should tuck nicely under the car.
Schwartz Performance
05-28-2014, 05:25 PM
You'll have to build something custom. There are several companies out there that do oval tubing. Not much in steel that I've seen, but stainless for sure.
Andrew is right a 2.5" is adequate though!
-Dale
Rwolf15241
05-29-2014, 05:58 PM
My target is 500 HP LS3 Crate motor. The car will sit very low
andrewb70
05-29-2014, 06:02 PM
Two and a half inch pipe is plenty for 500hp. Your car can't sit THAT low. The lowest point will probably the header collectors or the front crossmember. The exhaust generally tucks up higher than those two points. In other words, if you go too low, you will smash other things way before the exhaust pipes.
Rwolf15241
05-30-2014, 01:11 PM
I see alot of people running 3 inch, I think that is to large for a LS motor!!
69cutlassrkt
05-31-2014, 11:32 AM
I'm one of those guys ;)
Rwolf15241
05-31-2014, 12:38 PM
LOL, That's what I heard!!!
