View Full Version : 12 bolt rear housing
Sinnister69
05-23-2014, 02:44 PM
hey guys
where can i get a pre fabbed 12 bolt rear that works with the ridetech bolt on 4-link?
thank you!
Sinnister69
05-24-2014, 10:58 PM
Anyone?
raustinss
05-25-2014, 06:29 AM
Can't you just use a stock 12 bolt ?
Schwartz Performance
05-25-2014, 12:11 PM
You mean instead of welding your own upper link brackets onto? I don't know of anyone.
Sinnister69
05-25-2014, 04:10 PM
Yes like if it came as a pre fabbed package
GeoffP
05-25-2014, 06:15 PM
I'm pretty sure you can call Moser and get an axle from them already setup with the brackets welded on.
EDIT - I assumed it was a Camaro...should've read more thoroughly.
bad86ss
05-25-2014, 08:21 PM
I also believe Moser
05-25-2014, 09:07 PM
If Moser has the jigs for every upper control arm kit Ridetech sells then that'd be impressive!
What kind of car are we talking about? I'm assuming an Fbody.
-Dale
Sinnister69
05-26-2014, 08:11 AM
Yessir. Im restoring my 69 camaro. I already have the speedtech front sub with control arms
I would like to have a housing with everything on it for one, im not a fan of bolting on the lower bar mount. Rather have a nice welded bracket on. But i will call moser.
Thank you everyone
Sinnister69
05-27-2014, 06:17 AM
Moser emailed back saying they do not weld tabs on
GeoffP
05-27-2014, 04:11 PM
Have you called RideTech? I am 99% sure that Bret specifically said in one of the 48 Hour Camaro build videos that you can call Moser and order a ready built 12 bolt or 9 in with their brackets already welded in place. Maybe there just hasn't been enough demand for them to maintain the jig? I'd love to know what you find out.
Sinnister69
05-27-2014, 05:32 PM
Ride tech says they do not offer any housings. And also said that i am better off having measured snd welded my own tabs because they hsve found that people had to cut the tabs and reposition them anyways because they are slightly off due to differences in cars structure
05-27-2014, 08:03 PM
I would have figured that.
It's best to weld it in the car.
-Dale
Sinnister69
05-29-2014, 12:00 PM
Yes it made perfect sense
