View Full Version : 90' 454 out of a one ton pick up
t72ss402
09-19-2005, 05:11 PM
Does anyone have the ratinds for these engines? What year did chevy start to come out with the roller cam in there big block? Any info would be grateful
strangler
09-21-2005, 10:30 AM
Roller cam came out in 96 or 97 with the 'vortec' stuff (L29). Vortec engines have steel cranks, 4 bolt, forged rods and steel roller cams. No provisions for a mechanical fuel pump though. I dont know much about the tbi motors, but I think they are all cast componet 2 bolts. Both have non-adjustable valvetrains.
EFI69Cam
09-21-2005, 12:09 PM
The 98 or 99 L29 I just took apart had a cast crank and 3/8" bolt rods. Did have a factory roller cam.
sparky427
09-22-2005, 10:23 AM
The 88 -91 454's are all four bolt main with cast cranks and factory 3/8 bolts in the rods. They are still using the old two piece rear main seal. About mid way through 91 they changed over to the Gen 5 big block with a one piece rear main seal, cast crank, flat tappet cam, four bolt main, and changed the coolant passages in the heads. In 96 you get the Gen 6 with factory roller cam, four bolt main, revised oiling system, better heads, cast crank, stock 3/8 rod bolts, and they changed the coolant passages in the block for one last time. Where in Texas are you at? Hope this helps.
sparky427
t72ss402
09-25-2005, 05:07 PM
Thanks for all your information. I mainly bought the truck for the sepintine belt system for my 72 chevelle. but i think that i am going to drive the truck for a little bit.
i am in Ingleside Tx.
strangler
09-26-2005, 06:00 AM
Just rebuilt my 97 and it was a steel crank, with little rod bolts (3/8)
GMC 2500
