View Full Version : Need matching rotor suggestions.... C6-Z51 fronts with "LS1" rear
Nicks67GTO
05-02-2014, 05:29 PM
Title says most of it. I'm looking for a nice rotor to match C6-Z51 fronts with LS1 rears. I found some Powerstops but it sounds like I probably want to steer clear of drilled rotors for any kind of performance use?
I have to imagine that there is a selection because this is such a popular swap but i'm kind of coming up a bit short on my searches. Does anyone have any suggestions?
Decline
05-12-2014, 10:09 PM
*edit
Apogee
05-13-2014, 07:52 AM
Nick, are you no longer considering the Centric "High-Carbon" rotors? They're a decent quality and I believe have a plain finish IIRC.
Centric #12562065 98-02 F-body Rear
Centric #12562086 05-13 C6 Z51 Front
Tobin
KORE3
Nicks67GTO
05-14-2014, 01:44 AM
Tobin
KORE3
Tobin. I posted this before I started digging and found the other part numbers from Stoptech. I ended up going with a slotted only version of the Z51 front and LS1 rear. It took some digging but I found a few places that carried them and summit matched prices. They should be here soon!
Apogee
05-14-2014, 09:57 AM
It would be cool if you posted up the part numbers and descriptions for others enlightenment, as I know that there are others in the same boat as you, and also people with similar issues trying to aesthetically match up 325mm C5/C6 fronts with the 330mm C6 Z51 rears who could then follow in your footsteps.
Tobin
KORE3
Nicks67GTO
05-14-2014, 10:06 PM
Tobin
KORE3
Here they are....click on the part number link and a bunch of sub-numbers come up with descriptions and options. There were 19 options just for my Z51 fronts! You can get plain, drilled, slotted, drilled and slotted, 1 piece, 2 piece etc and even cryogenic treatment for any of them....
2011 Corvette
http://centriccatalog.com/Inquiry/AppResult.aspx?id=WEB_DISC&v=LD&y=2011&m=47&mm=440
2002 Camaro
http://centriccatalog.com/Inquiry/AppResult.aspx?id=WEB_DISC&v=LD&y=2002&m=47&mm=432
