View Full Version : 67-69 Camaro Detroit Speed rag joint conversion - steering coupler
Flash68
04-29-2014, 10:27 PM
Item Location (City/State): Norcal/East Bay
Price: $150
Description: For non-tilt stock column - Steel
Part # 092508
Paid $190 via MCB a year ago but never installed.
https://static1.pt-content.com/images/pt/2014/04/5A6B4781EB1041D297CD9CE9E1E12C17_zps4224-1.jpg (http://s236.photobucket.com/user/flash68/media/5A6B4781-EB10-41D2-97CD-9CE9E1E12C17_zps42245ewm.jpg.html)
cwylie
04-30-2014, 04:06 AM
So this works between the stock column and stock steering box?
Flash68
04-30-2014, 09:41 AM
Stock column, yes. I am not 100% sure on stock steering box as I bought it to use with an aftermarket frame and rack. Here is the detailed section on DSE site.
Steering Couplers
The Steering Coupler U-joints utilize the latest in CNC machining technology. The U-joints are made out of the highest quality steel and have been thoroughly tested. Similar to OEM automotive U-joints, the staked needle bearing caps prevent loosening and adjustment malfunction.
The shaft is a DD that can be easily trimmed to exact length needed. Shafts are 12" in length as received.
Also available are vibration reducers (DSE recommended) which significantly reduce vibration in the steering wheel and have also been shown to increase the overall life of the steering components.
The Steering Coupler comes in many different configurations which are listed below for you to properly choose the correct size and joint for your application. It is available in plain steel or polished stainless steel; as well as, with or without a vibration damper.
Note: On stock steering columns, verify output shaft type and spline before ordering. Please call with any questions.
http://www.detroitspeed.com/1967-1969-F-Body-products/032001-hydroformed-subframe.html
