View Full Version : My Modified and textured covan bezel and new vintage gauages for my 71 camaro
1976CamaroGuy
04-26-2014, 07:17 AM
Just wanted to share, it started life as a faux carbon fiber look. I don't have anything in my car that's carbon fiber.
I am mounting my turn signals from behind for a cleaner look, and also dremeled out a hole between the tach and speed which a panel lens with hi-beam, check engine, and brake warning led's are hiding behind.
I didn't want to just throw random led's in the bezel and call it a day like the pic below...going for more of a "what if the factory did it" look. Nothing wrong with this, I just think it can be improved on a little bit
I sprayed some texture paint on the bezel and it resembles the texture on a sheet of abs. After that I hit it with some sem landau black
Turned out pretty good so far
https://static1.pt-content.com/images/pt/2014/04/20140422174926_zps1f9fd1e6-1.jpg
https://static1.pt-content.com/images/pt/2014/04/fd053a7359f447efa1bc16abc8b30512_zps6dc0-1.jpg
https://static1.pt-content.com/images/pt/2014/04/6248d1e518f14d5ea63a010d05e72132_zps9819-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140423192255_zps627bc73d-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140423192249_zpse8126f0a-1.jpg
what I used...a 10+ year old can of plasti -kote texture spray
https://static1.pt-content.com/images/pt/2014/04/20140423150734_zps5d438829-1.jpg
I installed my lens and wired up my led's. I basically cut up the lens from my new vintage kit for my install.
For the turn signals I drilled holes in the bezel and used nylon spacers to mount the led's from behind the arrow lens . I hot glued the lens first then the spacer...it's really bright lol
I wrapped tape around it to diffuse the light from lighting up the spacer
https://static1.pt-content.com/images/pt/2014/04/20140424185451_zpseeba02ba-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140424185501_zpsf8937f91-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140424203546_zpsa466c24f-1.jpg
The lens actually has a texture face and blends in with the bezel when the led's aren't on...pretty low key
https://static1.pt-content.com/images/pt/2014/04/20140424203427_zpsb7a2f555-1.jpg
One thing I did notice was that my colors were reversed on the check engine and brake warning. I used the housing supplied by new vintage and the led's were already glued in. my kit came with a vertical lens and they sent me a horizontal lens free of charge so I guess there was a different layout between the two ....oh well it still looks pretty good
If I get some time I may make a new mount and re position the led's
https://static1.pt-content.com/images/pt/2014/04/20140424203453_zps87f37f12-1.jpg
CarlC
04-26-2014, 07:32 AM
Nicely done! I too dig making aftermarket parts morph into what would be an OE-type installation.
feeble
04-26-2014, 08:50 AM
Very nice, it does look factory! Where did you get the panel lens with hi-beam, check engine, and brake warning led?
1976CamaroGuy
04-26-2014, 09:35 AM
Thanks, it's part of a new vintage indicator kit that I dissected..
http://www.newvintageusa.com/panels.html
