View Full Version : Ps pump pressure
sam 74
04-24-2014, 03:50 PM
I have a type 2 pump that's rated at 1200 psi, I'm going to add hydro boost and have a concern about the pump not having enough pressure to run the steering and brakes, the box is a gm 800 12:1. The steering has a little road feel to itand I think that's from lower pressure than factory Saginaw pumps put out.
Later-A-body
04-26-2014, 01:48 AM
You will need to have your pump set up for the hydroboost in order for it to handle the higher PSi. I would recommend calling Lee Manufacturing in Sun Valley, CA. 818-768-0371. I have used them numerous times for my different hydroboost set ups. They are by far the best vendor for this.
sam 74
04-26-2014, 03:13 PM
What do you mean setup, will they mod it to produce more psi, i may just buy a different pump if my current one is not enough.
04-26-2014, 08:51 PM
Anyone tracking their car with hydro boost should get the Lee Manufacturung Crome Molly shaft for their old style P pump I've heard of stock shafts braking.
sam 74
04-28-2014, 05:33 PM
The car will be driven mostly on the street, if I have the time I may do an auto cross or two but with 2 young children thats probably not going to happen to often, but I'll definately look into the shaft just to be a safe.
