View Full Version : 2009 ctsv brake installed on a1970 camaro ,
Dog1
04-24-2014, 12:14 PM
I have bought c 6 spindles for the front every thing was a bolt on including using the v hubs and rotors , just need brackets or templates to install the rear brakes on a 9 inch ford rear end , which is out of Torino gt 1969 .
Help plz
srh3trinity
04-24-2014, 12:53 PM
The calipers were a bolt on? I thought the mounting bolts would space it out so far you would need about a 15 inch rotor. At lead t that is what I read on Corvette forums. From what I found, the zr1 calipers were different than the ctsv calipers. Are you running two different bolt patterns? 5x120 front and 5x120.6 rear.
csouth
04-24-2014, 01:31 PM
Help plz
Are you saying you used C6 spindles on your car? If so, what control arms are you using? You could actually make your own template after mocking up the rotor and caliper.
andrewb70
04-24-2014, 02:01 PM
Help plz
For future reference, please post in the correct tech forum. I am getting really tired of moving threads from the Open forum. Thanks.
Dog1
04-24-2014, 03:51 PM
Sorry , just learning this thing . I bought ccp spindles for a bolt on to the 70 camaro a arms . Also I am running the same bolt pattern all way around , had axles re drilled . Just need help fabbing up the rear
Decline
04-25-2014, 12:17 PM
Pics?
