CrisAnderson27
04-20-2014, 11:23 AM
Hey guys!
I've been doing some searching in the forums this morning (and for the last week via the internet as well), and can't seem to find any information on my specific issue. I think it's probably because the terms required to search are pretty generic...lol. I mean the words, 'Macpherson strut', 'LCA', 'lower control arm', and 'shortened' bring back millions of hits, no matter how you mix them.
Anyhow, what I'm building is a 1968 Cougar. It's currently a street/strip build, but as I'm going I'd like to make sure there's some future utility for other forms of performance driving in there. The engine is a 347, and should put out somewhere north of 700 naturally aspirated horsepower on out of the pump E85. The car will be street driven far more than it is raced (probably daily or close to it...I live in Phoenix, AZ lol). I'm starting out here talking about the engine because that's where the entire front end redesign started. The heads are monstrous...and the 2" primary headers aren't so tiny either. I first tried the standard big block 'notch the shock towers' thing...which was necessary just to get the valve covers on the heads. Unfortunately it was still a no-go for the headers. Some calculation showed me that even lowering the upper control arms by 2" wouldn't provide enough room. So I started researching front end options. First of course was the Mustang II setup, but I didn't like the additional weight, particularly on the nose of an already nose heavy car. I also didn't like that in order to provide the kind of structural integrity I wanted/needed...I'd need to run down bars from the cage to the front frame section. Next came the strut based kits...Fatman, AJE, Gateway, RRS. I've heard good and bad about them all...but the one big universal downfall was the ridiculous pricing. In looking over pictures, searching out install threads, and finding the less than a handful of guys who went their own way...I decided to design my own setup using 96-04 Mustang GT spindles and brakes, Strange 10 way adjustable struts with coil overs, and stock car type tubular LCA's with tubular adjustable strut rods to replace the factory setup.
This is where (finally) my question begins to come in. The rack I'm using is a Pinto/Mustang II setup. I originally intended to narrow it by approximately 3" per side to line up properly with the strut and LCA mounting points...but my headers are in the way if I narrow it at all. This led me to the option of cutting the LCA's down from the approximately 13.5"-15" they are currently (I've got about 1.5" of adjustment in the rod end), to somewhere between 11"-12.5". The LCA mount would be moved outboard roughly 3" from the center of the stock location, and up about 3/4". With the current setup, the LCA is just about parallel to the ground, and by raising the mounting point I figured it would help raise the instant center...which on a lowered MacPherson strut system can only be to the good. The problem is, I don't know if there will be any negative effects of shortening the lower control arms. I can grasp that it will shorten the arc the spindle travels in, but with the strut setup, I can't quite get a grasp on what problems that might cause, if any.
Let me post up some pictures to help illustrate both what I've done so far, and to help clarify my question:
https://static1.pt-content.com/images/pt/2014/04/20140411215803-1.jpg
LCA's and coilover setup.
https://static1.pt-content.com/images/pt/2014/04/20140415172308-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140415181017-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140415184446-1.jpg
Caster/camber plates.
https://static1.pt-content.com/images/pt/2014/04/20140415181140-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140415181117-1.jpg
Ride height is about 13.5" from the center of the wheel hub to the fender lip...which is about an inch lower than stock.
https://static1.pt-content.com/images/pt/2014/04/20140415181051-1.jpg
This picture's a little deceptive because of the angle. There IS a bit of negative camber, but it's nothing that the caster/camber plates and the adjustable LCA's won't be able to tune out. Track width seems to be just a hair wider than the original stock setup.
https://static1.pt-content.com/images/pt/2014/04/20140415182325-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140415182220-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140415181826-1.jpg
https://static1.pt-content.com/images/pt/2014/04/20140415181817-1.jpg
She's got a long way to go...but once the steering is finished, it's mostly going to be about lowering the engine, getting the cage in, and putting it back together.
And couple pictures to show what I mean, regarding my question:
https://static1.pt-content.com/images/pt/2014/04/20140418190610-1.jpg
This first pictures shows the rough centers of where the arms are going to be moved to. About an inch higher than the center of the stock location, and 3" outboard per side. This will leave my control arms somewhere between 11.5" and 13.5' long per side from the center of the rod end mount, to the center of the ball joint. I will actually mock it up backwards (mount it to the spindle first then measure inwards) to determine the right length. If I'm right, this should help substantially with the front roll centers, but I'm not sure if there's any negative side effects I should be aware of. Hitting corners at speed isn't the main concern here, but I want a stable, predictable car regardless of any reasonable amount of horsepower I throw at it. A car with stable geometry is a hell of a lot easier to get back in shape, if/when it decides to get out.
https://static1.pt-content.com/images/pt/2014/04/20140418190654-1.jpg
A picture showing the current control arm geometry. Not horrible for a lowered Macpherson strut from all I've read.
https://static1.pt-content.com/images/pt/2014/04/20140418191300-1.jpg
Here I'm just showing roughly where the strut rod mount will be placed to keep things properly triangulated. The strut rod will be an adjustable roller setup.
Anyhow, I just thought these might help explain my question a little...and thanks in advance for any help!
