View Full Version : PCS Trans Controller for the van?
astroracer
04-17-2014, 07:14 PM
I have looked through the current threads on trans controllers, just need some more info. Is anyone using a PCS trans controller? I have come up against a hard spot in the van build and, going to a remote shift controller, will solve a number of issues.
Just wanting to know how you like it and how well it works. I will pony up for the paddles also and would like info or comments on those as well.
I have a TH400 all built up with a twist Machine converter and a GV OD unit. Getting rid of the physical shifter will really simplify the engine cover/air cleaner clearance problems I have right now.
thanks
Mark
Steve Chryssos
04-18-2014, 09:34 AM
Their push-button shifter simply works the arm on the side of the trans. It does not need to interface with a controller. Therefore you can use it with any controller that you want. You should even be able to use it with your 400.
astroracer
04-18-2014, 12:16 PM
Thanks Steve, yup, I know how they work, I was just asking for real world use experience and if anyone would recommend them. This is a lot of money to spend when I have already spent enough on the TCI shifter. This set up will solve a lot of problems for me IF it works as they say.
Getting rid of the shifter will let me raise the top of the doghouse high enough that I can get an air cleaner on the carb. It also solves the doghouse removal issue (with a shifter bolted to it) and the worries I was having trying to tune the engine with the cover removed and the shifter dis-connected. To many what-ifs with that scenario and I was not comfortable with most of them.
What do you think of their product? Will it work well enough in my situation that I can comfortably get rid of the manual shifter mechanism?
Mark
astroracer
01-30-2017, 04:04 PM
Bringing this back from the dead zone. I'm hoping in the last couple of years someone has had some real world experience with these trans controllers. Anybody?
Mark
Craig@Bowler
02-01-2017, 10:36 AM
Mark,
From our experiences with PCS controllers I wouldn't hesitate to go that route. We primarily use Compushift just because we like their set up a little better, but we've used many PCS kits over the years as well without any issues. They make a great product. If there's any specific questions you have let me know and I'll do my best to help you out.
astroracer
02-02-2017, 09:38 AM
Thanks for the response Craig! I have emailed PCS and can never seem to get a response from them. THAT makes me wonder about their customer service. If they can't take the time to help a potential customer, I can only speculate what getting help would be like AFTER a sale. This is by no means a small outlay from my BadAst fund and I would feel better about it if I knew they were going to be there if I have issues...
Do you have a contact or know anyone there that would be willing to talk to me? Thanks again.
Mark
Craig@Bowler
02-02-2017, 12:42 PM
Mark,
I sent you a PM with some more info.
astroracer
02-12-2017, 08:40 AM
I big THANK YOU too Craig @ Bowler! He helped me out big time with this Trans Controller thing. I ordered the PCS System thru Bowler Friday afternoon with no reservations. It is a lot of money but it will solve so many problems it was the right way to go. I'll post up some pics when I get the stuff.
Thanks again Craig, I really appreciate the help bud.
Marlk
Craig@Bowler
02-13-2017, 02:37 PM
Mark,
I'm happy to help. Thank you for your trust in our company!
