View Full Version : 1973 Camaro,LS swap with Whipple
Razor
04-14-2014, 03:20 PM
****More photos and details posted below. If you chose to inquire via PM, do so by sending those PM's to screen name TheMeat*** Sorry for the confusion. It was a error made in haste on my part. ****
This is a spur of the moment thing but, I've found something else I would like to have!
My car has tons of $ thrown a it. Typing this on my phone but will edit later on PC.
1973 Camaro, 6 liter Iron Ls(450 ish miles), Whipple blower, 4l80e auto, Ford 9 " rear w/ alum center, Wilwood disks on rear, Boze wheels, 608 rwhp/672 rwtq. $35k.
http://m.youtube.com/?#/watch?v=eUqa6h7QbMw
Amigo-2k
04-14-2014, 07:30 PM
PM sent ...
TheMeat
04-14-2014, 08:06 PM
1973 Camaro, $35K, located in Tucson AZ.
-6.0 LS swap w/ 2006 rotating assembly, blue printed, decked, have spec sheet
new bearings, rings, balanced, ARP rod bolts, 10.6:1 compression,
-317 Heads rebuilt, surfaced, VJ, minor port clean up
-ARP head studs, Meling oil pump, Improved racing baffle
-LS9 head gaskets, Brian Tooley Racing PD blower cam, matching springs, Titanium ret., trunion upgrade
-ATI OD damper
-FIC 95LB injectors
-Nick Williams 102mm Throttle Body
-new wiring harness custom for car covered in black aircraft loom
-2" Hedman hedders, black ceramic coated
-Hedman x-pipe into magnaflow mufflers
Fuel
-stock tank sumped
-Holley 1800 twin pump, 1 pump on at all times, 2nd via 2psi Hobbs switch.
-Holley 10 micron and 100 filters
-Aeromotive fuel rails
-teflon -10an feed to pump
-teflon -8 to back of each rail
-teflon -6 to Aeromotive regulator then factory hard line to tank
Induction
-Whipple 2.3 liter intercooled supercharger
-5 gallon trunk mounted tank
-Jabsco pump
-grill mounted heat exchanger
-8 rib drive with 2.75 pulley
-13 pounds of boost
Transmission/driveline
-4l80e
-Trans go HD2 kit
-G Force crossmember
-Yank SC3000 converter
-3.5" aluminum drive shaft
-solid 1350 u joints
-ford 9"
-Yukon Aluminum center section 3.70 gear
-31 spline Mark Williams axles
-Detroit tru trac
-1/2" studs
Suspension/wheels/brakes
-Wilwood disc brakes on rear (15" wheels fit, no problem)
-factory front disc
-Caltrac lowered split mono leafs
-Caltrac traction bars
-Global West sub frame connectors
-Global West shackle kit
-QA1 single adjustables on rear
-QA1 coil overs on ront
-Boze 17x8 front wheels
-Boze 18x10 rears
-245-40-17 Nitto Invo, 295/35/18 Nitto Invo rear
-Solid body mounts
Interior
-new carpet, package tray, headliner, dyanmat on floor, trunk, package tray
-Boston Acoustics 6x9 and 3" fronts
-Alpine stereo with IPOD and thumb drive connection
-Scat procar rally 1000 seats with rears covered to match
-Autometer 5" CF tach and speedo with CF accessory gauges to match
-Anvil carbon fiber pillar covers
-AEM wideband
-CF Autometer boost gauge
-Quicksilver sifter
Car is Gm 51 Yellow with black racing stripes. I have the stock flat hood but it no longer fits with the Whipple. The car currently has a factory steel hood with a L8 8style scoop attached for clearance. It is scheduled for paint May 1st.
I just had the car dyno'd and tuned. It runs on E85 and is not set up on the ragged edge of safety. This car turns heads everywhere it goes and I have owned it for approximately 7-8 years. As I stated, this is a spur of the moment sale so, if my intentions do not plan out, I will remove this ad. I honestly had no plans of selling this car...EVER. You could not replicate this car for what I am asking.
https://static1.pt-content.com/images/pt/2014/04/beachandcar025-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/beachandcar025.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/beachandcar027-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/beachandcar027.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/beachandcar032-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/beachandcar032.jpg.html)
https://static1.pt-content.com/images/pt/2012/04/beachandcar045-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/beachandcar045.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/beachandcar031-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/beachandcar031.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/_DSC00771-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/_DSC00771.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/20131215155053_zps6a68a3f1-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/2013-12-15155053_zps6a68a3f1.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/20131215153354_zps95ea80a0-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/2013-12-15153354_zps95ea80a0.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/20131214135515_zpsf04cc6c2-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/2013-12-14135515_zpsf04cc6c2.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/20131101212931_zpsd37443e7-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/2013-11-01212931_zpsd37443e7.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/20131020151002_zps02cc4998-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/2013-10-20151002_zps02cc4998.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/20130721191229_zps9b3ebb3f-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/2013-07-21191229_zps9b3ebb3f.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/20130706185440_zpsb4118dab-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/2013-07-06185440_zpsb4118dab.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/20130102213930_zpsc0412c42-1.jpg (http://s201.photobucket.com/user/Rays_Viper/media/2013-01-02213930_zpsc0412c42.jpg.html)
TheMeat
04-14-2014, 08:08 PM
PM sent ...
None received...?
I am sure I have missed some things in the description but feel free to ask.
andrewb70
04-15-2014, 05:27 AM
Not sure what's going on here, but this needs to be cleaned up. The OP is Razor...but then TheMeat posts more details....
Figure out who is actually selling and make it clear...
TheMeat
04-15-2014, 05:44 AM
Sent you a PM.
to clear anything up, both screen names belong to me. I had forgot that I originally registered on this site with screen name Razor. I use that screen name on most forums but if it is not avail, I use TheMeat. In my haste to post this yesterday via cellphone, I typed in Razor as my screen name. Upon returning home to my PC, I logged on with my "usual" user name TheMeat. It appears that I had originally registered for this site 2 years prior to re-registering without even posting!
Hope this reads clear.
Thanks.
LS1-IROC
04-15-2014, 06:05 AM
Where is the car located?
TheMeat
04-15-2014, 06:09 AM
Tucson AZ
