View Full Version : DELCO Moraine OEM FRONT BRAKE CALIPER big bore 4piston heavy-duty brake option
turbo corey
04-11-2014, 12:53 PM
This listing for a set of front calipers.the calpers work good i just toke them off to go with z06 brakes 450$
4 piston 2 1/16" bore disc brake calipers using casting numbers 5455946 & 5456008
Donovan
04-11-2014, 08:14 PM
Hi Corey
do you have some detailed pics to share?
Where are you located?
I assume you are keeping the spindles but selling the calipers with a mounting bracket and rotors?
turbo corey
04-12-2014, 10:01 AM
if you text me i can give you all the pics you need (352 585 3567) this is just the calipers and lines
turbo corey
04-16-2014, 04:25 AM
450+shipping
wendell
04-16-2014, 01:44 PM
Part numbers? Are these twin pins or just c3 calipers? Have they been sleeved? O-ringed?
turbo corey
04-17-2014, 05:36 AM
wendell
04-18-2014, 05:58 AM
Gotcha. Thanks.
turbo corey
04-18-2014, 10:57 AM
This listing for a set of front calipers.the calpers work good i just toke them off to go with z06 brakes 450obo
this is a good upgrade
