paint2361
04-09-2014, 06:19 AM
1st gen Camaro, stock sub frame with Global west suspension. I'm thinking of tweaking the front end more. Options I have are the Guldstrand mod, .5" taller ball joints or the .9" taller ball joints or a combo of taller ball joints and the Guldstrand mod. What do you guys think?
Pontiac Chris
04-21-2014, 12:27 PM
I have a Global West Upper control arm with a .5" taller upper ball joint and it works well, I found it performs better with a -2-3 degrees negative camber on the Goodguys autocross. If you can get a .9" taller upper ball joint then do it, it should have even better camber gain.
Cheers,
Chris
