voice1000
04-03-2014, 06:52 PM
I will be installing my manual transmission soon.
Most likely end of May or beginning of June. Again just letting you know what I will have for sale. It will fit 68 and 69 Camaro and I am not sure about Chevelles.
Give me an email if your are in the area you can see and come for a drive with me and feel the performance of the transmission
Parts Included
700R transmission rated to 450 hp and torque. And Hardware
Lock-up converter with 1800 stall.
Speedometer Gear Set up for 3.08 rear.
Stainless steel cooler lines preformed
153 tooth heavy-duty flex plate. And Hardware
153 tooth General Motors mini starter And Hardware
Complete driveshaft.
Proper crossmember and transmission mount (not a modified original.)
(Price today 175.00)
Horseshoe shifter with proper detents for the shifter.
Shifter cable
All of the parts for the convertion of console. Cover where shifter goes through, all with proper labeling for the four-speed automatic.
Reverse light and neutral safety switch.
TV cable assembly made for fuel injection (you may need to change it for carburetor.)
Proper dipstick and tube (low hood)
Brake pedal (Disc Brake Pedal Pad Chrome Trimmed) (original)
Unit is perfect less than 5000 miles on transmission. It's still in the car and you can get a chance to drive it and feel how it is before you buy it.
Pressure gauge with 4 foot hose for setting the TV pressure properly on 700 R4 Transmission. $75 value.
Greg B 1969 Camaro convertible. $1500 total for everything.
Email [email protected]
Parts Included
Shifter cable
