View Full Version : Safe amount of time
paulk68
04-03-2014, 12:57 AM
What is a safe amount of time for a crate LS3 to sit around before getting installed and fired up?
Schwartz Performance
04-03-2014, 04:34 AM
If you store it for more than 4 months without oil then I would take the valve covers off and pour a little oil over the valve train.
Otherwise you can store it for a very long time, as long as it's not in a grass field or susceptible to a lot of moisture. Cover all the open ports too.
-Dale
sccacuda
04-03-2014, 12:15 PM
You'll want to pressure prime it before you start it, why not go ahead and buy the primer and hit it with pressure every few weeks and give it a spin. I like to use a light fogging oil down the intake to help keep cylinders above the pistons corrosion free.
