View Full Version : 67 camaro wheels
hadloric002
04-02-2014, 03:51 AM
Hey guys im looking to run something different on my 67 camaro like the TSW valencia in black i put the sizes with 2 options to each one below, my question is would these fit. I have a full ridetech coilover suspension.
18x8(1.5"lp)
5.75" bksp +32mm offset
5.25" bksp +20mm offset
9.5 (3" lip)
6.875"bksp +40mm offset
6" bksp +20mm offset
JLMounce
04-02-2014, 08:55 AM
You'd have to measure to be certain I think. The offsets are a bit on the high side. I'd go with the 5.25" backspace on the 18x8 and the 6" backspace on the 9.5. You might need to run a 1/4 to 1/2 inch spacer front and rear.
hadloric002
04-02-2014, 12:27 PM
Yeah i did the yard stick measuring tool thing and it was questionable so i figured i'd ask on here
Z06vet
04-02-2014, 03:59 PM
With a stock width rear end I have successfully run several 9.5" wide rears with 5.5" BS. Different brakes, rear end width, ride height, etc will all play a factor. Scott
JLMounce
04-03-2014, 08:19 AM
I looked at those wheels and another thing to keep in mind is that they are a 5x120mm bolt pattern. Although it's close, it's certainly not a 5x4.75. The wheel will technically fit over the studs, but you run the risk of shearing the studs.
Given the fact that you'd probably have to run a spacer anyhow, you could purchase adapters to change your lug pattern to 5x120. That would solve both the backspacing issue as well as the bolt pattern issue.
hadloric002
04-03-2014, 03:45 PM
Oh no i am 5x120 corvette brake swap and such which puts me to 5x120 thanks for the thought
