Nicks67GTO
03-31-2014, 04:18 PM
Title says most of it.
Iv'e got the SC&C stage II setup with Ridetech HQ's, SC&C spec'd SPC springs, Currectrac RCA's and Hellwig chassis mounted swaybar on a moser 9" Rear and ABC aluminum body mounts. The frame was fresh off the frame shop rack, straight as an arrow and practically fell in. Its not tweeked. The rear axle is located perfectly front to rear in the 1/4 panel openings.
The front of the car is pretty much level side to side. A touch high on the passenger side but I think its off because the back is way off and its pulling everything up with the boxed frame. Anyhow Iv'e measured about everything. The car structure seems like its all spot on. I measured shock compression and there's over 3/4" difference at ride height between the two rear shocks. The only other thing i'm seeing is a difference in rear compressed spring coils center to center at ride height. Its compressing well on the driver side and not on the passenger side. Like 1/4" per coil difference. 5 coils and you have 1.25" The back doesn't seem like its binding, everything is well lubed, was tightened at ride height iv'e swapped springs around side to side, that didn't help so i cant imagine its mismatched springs.
It seems like its got to be mildly binding enough to not allow it to settle but I can push it below ride height. Im kind of at a loss. I think tomorrow i'm going to go loosen everything up, unhook the rear swaybar and cycle it some more to see if that does anything.
Anyone got any other suggestions? I'm kind of thinking out loud and I wont be able to call Marc until a bit later in the day.
