View Full Version : What Elecric fuel pump should I buy?
Zachalanche
03-31-2014, 08:59 AM
I'm building a fuel system for to support a carbureted 427 stroker that has been dyno'd at 560 hp. I'm thinking 50 gph should be enough (correct me if I am wrong). there are a lot of choices out there as far as electric fuel pumps go, just curious if any of you had and experience based opinions on what pumps would be best for this application.
thanks.
Zachalanche
03-31-2014, 12:07 PM
thinking about this one.
http://www.summitracing.com/parts/hly-12-801-1/overview/
Schwartz Performance
03-31-2014, 02:39 PM
Id go with the Holley blue pump not the red. Summit has a kit that includes a regulator too.
-Dale
sam 74
03-31-2014, 03:25 PM
I'm useing a holley black pump on my 470 making 550 hp, I also have a holley blue as a backup, it was for my old nitrous setup that I sold and figured that it was a good pump just a little loud so its a good backup part. Either of these pumps can support your setup. A Holley red isn't going to cut it at WOT.
Red67Mustang
03-31-2014, 03:26 PM
I've used that style of pump in the past (I had the red one). Generally worked OK but crazy loud. I ended up replacing it just to get something that didn't annoy me as much as that Holley pump did.
Zachalanche
03-31-2014, 09:11 PM
are the holley black or blue any quieter? hows the reliability?
Shaker455
04-02-2014, 07:21 PM
Holley HP 150 is a great pump & quitter than the rest.
sam 74
04-07-2014, 05:14 PM
The Holley black pump I have is about 10 yrs old, never rebuilt, but The car isn't a daily driver. The blue was used only at the track with my nitrous system so i couldn't give an accurate account about running time on it.
Derek@ModernSpeed
04-15-2014, 11:55 PM
All the Holley red, blue, black pumps are rotor/vane pumps. They will be really noisy. I'm not a fan of them for other reasons that I won't disclose. If you want a pump that will dead head I would look at the Holley 12-125 or 12-150. Gerotor design is much quieter. Another option if running a return style fuel system is the fuelab prodigy pump. Excellent product.
Motorcitydak
04-16-2014, 02:23 PM
I would never consider anything except an in-tank pump. No worries about vapor lock and they are more reliable. You could modify just about any sending unit to hold a pump
65-fastback
05-10-2014, 12:36 PM
I have a aeromoive and it is 100 times better than the holley red blue or black.
BUT, i am considering to switch to the new holley, 105 or 140 version (i have 700+ HP N/A)
http://www.summitracing.com/int/parts/hly-12-1400/overview/
Brand:Holley
Manufacturer's Part Number:12-1400
Part Type:Fuel Pumps, Electric External
Product Line:Holley Dominator Billet Fuel Pumps
Summit Racing Part Number:HLY-12-1400
UPC:090127671092
Free Flow Rate:105 gph
Maximum Pressure (psi):80 psi
Inlet Size:-10 AN O-ring
Inlet Quantity:One
Inlet Attachment:Female threads
Outlet Size:-10 AN O-ring
Outlet Quantity:One
Outlet Attachment:Female threads
Quantity:Sold individually.
Notes:Maximum draw is 23 amps.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
These Holley Dominator billet fuel pumps feature a patent-pending twin-pump design. It allows you to use one pump for cruising and both pumps when you activate the nitrous switch or start building boost. By staging the second pump, you eliminate the unnecessary recirculation and heating of extra fuel, which can lead to poor performance and hot fuel issues. They can also be wired for full-time duty to get the maximum performance and are proven with an 18 V compatibility at pressures of up to 80 psi. At only 5.1 lbs., they weigh half a pound less than other 1,000 hp pumps, and yet they have twice the features.
Features include:
* Billet aluminum construction with anodized finish
* -10 AN O-ring inlet/outlet for high flow and superior sealing
* Excellent for use with carburetor or EFI applications
* Compact for easy installation on frame rails or other tight spaces
* Proven durability beyond 3,000 hours in gasoline or diesel fuels
* Fully sealed, can be submersed if necessary
Anyone experience yet?
Nothingface5384
05-10-2014, 02:07 PM
id go with intank if you can swing it
I Have liftpump and fuel surge tank avail if you go with inline Epump
juggernaut
05-19-2014, 06:27 PM
I've ran a holley blue and haven't had a problem with the pump, except for it being noisy. I bought a Jegs "Quiet Flow" to try to alleviate the buzzing. Anndddd... The QF pump is underwhelming. It still buzzes, maybe a slightly less than the blue. One advantage is the regulator is built into the pump. It makes for a cleaner engine bay. :)
