James OLC
03-29-2014, 11:18 AM
1967 Camaro custom modified front subframe (will fit 1967 - 1969 F-body and Nova). Fully seam welded, converted for coil overs using SpeedTech ATS Chicane kit, SpeedTech high clearance upper and lower control arms, ATS AFX billed spindles with SKF hubs and ARP wheel studs. Custom modified centerlink, 2nd gen outer tie rod ends, custom built steering arms, custom valved RideTech triple adjustable shocks with Hyperco coil springs, Baer 14" rotors, Lee Engineering 670 Steering box, ATS LS engine mounts. Also includes all stainless steel brake lines. First Chicane subframe built by ATS and featured in the 2008 SEMA Show. Subframe was powder coated (titanium) and then sanded and painted.
and
ATS Tri-Y stainless steel headers and 3" Magnaflow exhaust system. Custom modifications to the headers to address low hanging collectors common with these rare pieces. Fit all LS engines including LS7, can include new ls7 header gaskets and bolts. Exhaust system includes Magnaflow true-x crossover and stainless mufflers. Ridicules amount of work done on exhaust (welds ground smooth, etc). Entire system - headers, exhaust, and mufflers - Jet Hot coated (titanium finish).
This is a bolt in and go solution to get your LS project up and running fast immediately.
I have $8500 in parts/labor and countless hours/$s in tuning on the subframe and $4500 in the exhaust - asking $5500 plus shipping (prefer local pickup) for the subframe and complete headers and exhaust - will not separate. Subframe and exhaust is located in Salinas, CA.
Subframe construction pics:
https://static1.pt-content.com/images/pt/2014/03/120ats20sub201-1.jpg
https://static1.pt-content.com/images/pt/2014/03/220ats20sub202-1.jpg
https://static1.pt-content.com/images/pt/2014/03/320ats20sub203-1.jpg
https://static1.pt-content.com/images/pt/2014/03/620ats20sub206-1.jpg
https://static1.pt-content.com/images/pt/2014/03/720ats20sub207-1.jpghttps://static1.pt-content.com/images/pt/2014/03/820ats20sub208-1.jpghttps://static1.pt-content.com/images/pt/2014/03/920ats20sub209-1.jpg
https://static1.pt-content.com/images/pt/2014/03/1020ats20sub2010-1.jpg
https://static1.pt-content.com/images/pt/2014/03/1220ats20sub2012-1.jpg
and
