View Full Version : Enough front suspension travel?
woody80z28
03-24-2014, 06:15 PM
I've searched around and found a lot of numbers for the back, but not the front...and surely the requirements are a little different.
I am doing fender surgery to get the tire clearance I need and mocking up my final ride height. I'm curious what would be a good spec for the upward travel...downward I have plenty.
Stock 2nd-gen subframe and control arms (unsure of travel ratio between spring/wheel)
600lb Hotchkis coils
25.5" to fender lip at my proposed ride height
22.875" to lip on bump stops
That leaves me with 2.625" of compression travel, but that is resting on the bump stop...so figure 2.5 or so of free travel. Is this in the ballpark for my spring rate? How would I calculate it?
Thanks for any help.
Ride height:
https://static1.pt-content.com/images/pt/2014/03/IMG_9078-1.jpg
03-24-2014, 07:06 PM
What is the bump stop to A arm clearance at ride height?
I think you are OK but barely.
If you dial in some negative camber, the tire top will move inward. -2 deg camber will move the top of the tire inward an inch.
woody80z28
03-24-2014, 07:21 PM
I will check and get a measurement. If it needs to be more I can cut the bump stop slightly or raise the ride height.
Tire-wise, clearance everywhere is fine, and that is with the pos camber because it was aligned higher. I made custom inners and reworked the lip. Even on the bump stops it clears.
