View Full Version : Stainless Trim Blackout
rizzo
03-22-2014, 08:40 AM
Its hard to believe that nobody as every posted this mod...... as I have search to no avail.... I want to matte black my SS window trim and drip rail to last forever... Do I glass bead blast Etch primer and 2k rat trod black or do I use epoxy primer I cannot find any solid answers... I have read PC adds thickness which is not conducive for me here...please help ???
raustinss
03-22-2014, 02:09 PM
What about anodizing the trim....it's a route I might go
Ryan Austin
rizzo
03-22-2014, 04:48 PM
you cannot anodize Stainless.... Aluminum only
Chadman27
03-22-2014, 08:20 PM
Sharpie! JK, I'm curious to see what others are doing here too...
spacepirate
03-22-2014, 08:22 PM
plasti-dip even though it's not permanent
Jdinjax
03-23-2014, 02:39 AM
+2 on Plasti dip spray. It is surprisingly durable and looks great.
raustinss
03-23-2014, 02:44 AM
Let's not start a fight but there are many ways to coat stainless....i guess I chose the wrong word when I said anodize
chevelletiger
03-23-2014, 05:59 AM
im going to powder coat mine,most builders have so i dont think there much problem with film build thickness.price is an issue thought i had got a quote of $200 to do front and back window trim and cowl trim.
phil
Schwartz Performance
03-23-2014, 07:47 AM
We usually powdercoat ours too. I personally haven't installed trim after powdercoating- I would also be afraid of it cracking, but the guys have done it several times.
You could also wrap it in vinyl I suppose..
-Dale
Craig510
03-23-2014, 07:57 AM
phil
That sounds like the shops minimum charge. We get a lot of parts coated at work. Most of the time we need a fast turn around and pay the lot charge, but you might be able to Sweet talk the owner into running your parts with a production lot. We do this on occasion with black or white parts.
raustinss
03-23-2014, 08:03 AM
Has anyone ever done a black chrome finish?
gak68
03-23-2014, 02:14 PM
what about manganese phosphate; that what they use to on gun barrels, its super durable and once you rub oil into it, it will have a nice deep matte black finish
Jetfixr320
03-23-2014, 06:35 PM
Plenty of white lithium grease on both parts and snap the trim back on. Wipe the grease off. Or at least it worked for me without damaging the paint or powder coat.
jlcustomz
03-24-2014, 08:37 PM
If you wanted to try plasti dip or dupli-color engine enamel, spray a coat of adhesion promoter first. Adhesion can be an issue with stainless. Even powdercoat can chip easy applied on a tough to bond to surface.
icemanrd19
08-03-2016, 07:06 PM
SEM trim paint worked great for me.
If it gets scratched you just tape it off and respray. SEM trim paint is easy to touch up. I used SEM trim eurojet satin black
https://static1.pt-content.com/images/pt/2016/07/13769375_10100886156138276_1241284079465-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/13769375_10100886156138276_1241284079465533127_n.j pg.html)
https://static1.pt-content.com/images/pt/2016/07/13754162_10100886156038476_2431037668082-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/13754162_10100886156038476_2431037668082816445_n.j pg.html)
https://static1.pt-content.com/images/pt/2016/07/13645154_10100886156088376_4367068389282-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/13645154_10100886156088376_436706838928233391_n.jp g.html)
https://static1.pt-content.com/images/pt/2016/07/13668957_10100886156193166_2231179250796-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/13668957_10100886156193166_2231179250796225921_n.j pg.html)
https://static1.pt-content.com/images/pt/2016/07/13770351_10100886155918716_7419150446723-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/13770351_10100886155918716_7419150446723191857_n.j pg.html)
andrewb70
08-03-2016, 08:06 PM
Is that the same as Melonite?
BonzoHansen
08-04-2016, 05:53 AM
Some late scond gens came with blacked out aluminum trim. Many folks have reported excellent results with powdercoat
hifi875
08-04-2016, 06:15 AM
brushed mine
Z06killinSBF
08-04-2016, 03:51 PM
I repaired the trim on a couple cars with the SEM trim paint, not sure on the material though.
Nine Ball
08-06-2016, 02:54 AM
I powdercoated mine silver, no issues reinstalling it. On the wide 2-piece trims, you simply have to open up the slot a bit when assembling - due to the coating thickness. But, pretty simple to assemble.
