View Full Version : Hurst Line Loc question
minendrews68
03-21-2014, 04:05 PM
I am using a Hurst Line Loc, brand new, I tried it out today and although it holds the front tires, I don't think it's releasing. Something is holding the brakes. has anyone else had this problem? I'm not drag racing, I'm just a gadget guy I guess.
Schwartz Performance
03-21-2014, 06:46 PM
Do your brakes work fine without the LL engaged?
minendrews68
03-22-2014, 06:10 AM
yes they do. I think I'm going to have to bleed off the pressure to release the front brakes. I'm wondering if maybe the pressure is too great for the valve to release, just a thought though.
03-22-2014, 11:47 PM
should release pressure as soon as it is de energized, how is it plumbed in? between master and combination valve? after combiation to a tee to front brakes?
MonzaRacer
03-23-2014, 10:05 AM
Should be inline from master cylinder then too combo valve, BUT some prop valves have issues with returning to center. I actually prefer to swap in adjustable units, and for the fact of the matter adjustable one will let you fine tune even stock brakes, which does help the brakes to operate more efficiently anyway. so my theory is to dump the stock prop valve, adjustable can be had for less than $75 and really can help braking performance as you can adjust to newer pads/shoes/etc used as upgrades or "fixes" like the newer low dusting ceramics DO have better efficiency and if used on back brakes might change vehicle dynamics some.
minendrews68
06-16-2014, 06:16 AM
Lee,
do you have any information on the adjustable prop valve? I really think now that the LL isn't my problem. It seems that the hold without using the Line Loc.
Never mind, just googled it and found some info. Thanks
Skylark
07-21-2014, 04:12 PM
Interested in what you figure out. I'm having this exact same problem with the same product. Will be doing a rear disc swap next week hopefully and will buy an adjustable prop valve to see if that fixes the issue.
hotrod937
09-10-2014, 11:11 PM
Yeah what did you find out about this. I also have one of these new in box and just don't trust it.
minendrews68
09-11-2014, 06:16 PM
Mine wound up not being the Line Loc. I had my brake pedal rod adjusted too tight and when I drove the car and the engine compartment and brake fluid heated up it forced the pedal against the stop and the brake fluid at that point had no where else to go but to the brakes. I haven't tried the LL again I'll try it this weekend and let you guys know if I still have the problem. I hope not...
Carl
