View Full Version : double PCV?
RobM
09-15-2005, 04:16 PM
can i run two PCV valves for extra positive crank case ventalation? I would think it would increase all the benifets of a normal pcv/ breather set up
CoryM
09-15-2005, 05:49 PM
If you like. Some PCV draw more gas through though so if you get a larger one, you probably only need one. Just remember that a PCV is just a controlled vacuum leak so dont get carried away.
WS6
09-15-2005, 06:32 PM
well the PCV is the exhaust side of crankcase ventilation, so you still need an intake side for the crank case. you can run two PCVs but they need to be on the same side. the inlet will need to be on the other valve cover.
