View Full Version : camaro front tire size
lbluecamaro69
03-16-2014, 09:03 AM
does anyone know if i could fit a 235/70r15 tire in a stock 1969 camaro front wheel well? it has hotchkis 2" drop springs and the tire height would be 28". the reason is that i want my front to match my rear tires and I'm looking at the bfg redline radials
thanks
77thor
03-16-2014, 03:42 PM
IMO, it should work fine. That's a fairly narrow tire.
I was running 235/60/15 up front on mine without problems.
lbluecamaro69
03-17-2014, 08:47 AM
i was more concerned about the height of the tire because it is a pretty tall tire at 28 inches
lbluecamaro69
04-12-2014, 04:50 PM
Update: they rub in 3 spots at full lock and barely clear when the tires are straight:(
TheJDMan
04-13-2014, 01:48 PM
If you remove the inner fender bolts and replace them with button head screws that should solve one clearance issue.
