View Full Version : 93 M29 T56---freshly rebuilt by Texas Drivetrain Performance
HotRodV6
03-07-2014, 04:46 PM
I have a 93 M29 Close Ratio T56, it has the same gear ratios as the 2001-2004 ZO6 corvettes. It has been freshly rebuilt to stage 2 specs by Texas Drivetrain Performance in Ft. Worth. It has the bell housing, clutch fork and pivot, & the slave cylinder spacer. I also have a lightly used B&M Ripper shifter with a B&M Hammer T-Handle, a new bronze shifter bushing, and a new stock replacement clutch kit that goes with the trans, and a stock replacement flywheel.
This trans does not have the skip shift solenoid, it was removed from a 93 trans am and was stuck in third gear when i bought it, i thought it was a busted shift fork, but it turned out that one of the synchronizer keys came loose on third gear causing it to be locked in gear. everything else in the trans was very clean, only some slight wear on the main shaft, which TDP welded up the shaft and machined it back down so that the gear/bearing has an actual press fit rather than the factory slip fit.
SOLD SOLD SOLD
HotRodV6
03-10-2014, 06:02 PM
bump ttt
HotRodV6
03-12-2014, 06:50 PM
bump ttt
HotRodV6
03-15-2014, 04:01 PM
bump ttt
HotRodV6
03-17-2014, 04:21 PM
Bump ttt
wanted to add that i now have the slave cylinder spacer, and a new stock replacement flywheel and that the clutch kit will come with ARP pressure plate bolts.
HotRodV6
03-24-2014, 06:01 PM
Bump ttt 2800 is about as good as the deal gets for an awesome trans setup!!
HotRodV6
04-08-2014, 04:44 PM
bump ttt
HotRodV6
04-17-2014, 10:48 AM
Bump, i know somebody needs an awesome bolt in T56 kit for there build, and 2800 shipped for everything is a dam good deal.
1969sschevelle
04-18-2014, 03:17 AM
I need it! But dont have the money! LOL
HotRodV6
04-26-2014, 08:03 PM
Sold sold sold.
