View Full Version : Vincent's Pro Street 1975 Volvo 242 "MazdaSwede"
Mangohick
03-06-2014, 05:07 PM
Hope you guys don't mind me posting updates on my Pro Street build. I've always loved fat tire cars so I decided I should build a Volvo since I've had over a dozen since I was 16. The chassis is design has a emphasis on backbone stiffness and four link support. Tubing is .095" 1-3/4 DOM for most of the structure. The firewall has been moved back 5" to accommodate for tighter mass centralization as well as moving the engine up to keep the pan off the ground while cruising.
-Vincent
-75 Volvo 242GL
-2JZ-GE
-6 speed 4L80E with PCS valve body mod
-Narrowed 9"
-Weld 15x15 RT-S wrapped in 31x18.50 Hoosier QTP DOT's
-Custom made DOM chassis designed by Joshua Mazerolle (Vague Industries)
-Phantom Electronics touch starter
-PCS Dashlogger, TCM, EGT module and touch button gear select module
-Built in my garage on a "pallet"
105659
105658
105656
105657
105655
105654
91429
snopro
03-06-2014, 05:45 PM
Im looking forward to seeing all that tube work welded up
Mangohick
03-31-2014, 04:07 PM
Got the main hoop bent and tacked into the car..
92938
92939
92946
Cut the trunk hinges out and test fit the wheels again.
92947
Tires are 31"x18.50" Quick Time Pro's On Weld Racing RT-S 15x15 wheels.
92948
Tig
03-31-2014, 04:41 PM
Oh wow, this is going to be good.
Nice tight fit for that main hoop, lookin good man.
Looking forward to your updates.
Mangohick
04-02-2014, 09:45 PM
Thanks Tig!
Starting to look a little more busy in here.
93096
93097
93098
93099
Twentyover
04-06-2014, 05:31 AM
Mango-
You like the gear ratios on the 5R55E? Reason I ask is over on Turborangers a guy built an adapter plate for duratech 4's that adapts the 302 bell pattern, and he has a 157 tooth flywheel so you can get a 10.5 inch clutch. Maybe worth a look
Just an option
Mangohick
04-24-2014, 08:57 AM
Mango-
Just an option
I like that idea.. I may run that in my daily driver. I've decided to skip the duratec4 and go LS.. For more trans options..
Mangohick
04-24-2014, 09:06 AM
I've been really busy but still taking out a few hours around midnight to fit tubes.. Almost have the four-link truss finished. Time to buy some tubing!
94515
94516
Notch setup
94517
94518
94519
no go nova
04-25-2014, 01:55 AM
Your doing great work in your garage.
Tig
04-25-2014, 04:34 PM
Awesome, lovin the tube work.
What are you using to bend the tubing? DOM correct?
Great job man.
Mangohick
04-29-2014, 12:10 PM
Thanks No Go! I cant wait for the day when I get a shop with a lift!
Mangohick
04-29-2014, 12:12 PM
Great job man.
Thanks Tig! I'm using a JD squared model 3. Tubing is 1-3/4 .095" wall DOM.
:) My fab skills aren't good enough to warrant Cro-mo..
CadillacMazerolle
05-03-2014, 06:38 PM
Love this build!!!!
Mangohick
05-09-2014, 07:18 PM
Bending and fitting the cowl bar
95396
95397
Mangohick
05-24-2014, 06:19 AM
Finished up the firewall/cowl area. Starting on the front node for the backbone.
96249
96250
96251
96252
96253
96254
96255
96256
96257
96258
no go nova
05-24-2014, 08:14 AM
Man That fab work looking great. That Volvo gonna be a beast.
dangina
05-24-2014, 11:04 PM
I love where this is going!
Mangohick
06-19-2014, 03:37 AM
Got a few more tubes fitted..
97718
97719
97720
Getting the Mazderp engine ready to stab back in my other Volvo
97721
97722
Cant forget cup holders for Sonic runs :headbang:
97723
Mangohick
06-29-2014, 06:47 AM
Finally got some time to lay some tubes.. Got the top of the backbone x finished up today. Definitely took me the good side of 5 hours to fit three tubes..:screwy:
98331
98332
98333
98334
98335
Tig
06-29-2014, 05:25 PM
Awesome updates.
I think you're wrong, you are definitely capable and skilled enough to do a chromoly chassis. Heck your tubing notching and alignment is damn near perfect.
Great work man.
Mangohick
06-30-2014, 10:05 AM
Awesome updates.
Great work man.
I really appreciate the kind words! Lets just say I'm hiding a few big gaps here and there :secret:
..well that and I also don't know the first thing about TIG welding.. Once I buy a machine and get comfortable with it I'll switch over to 4130.
knuckleworks
07-01-2014, 07:31 AM
great stuff :)
/janne
CadillacMazerolle
07-04-2014, 09:23 AM
i heard there was more updates...... lets seee it!
Mangohick
07-06-2014, 08:33 AM
My chassis designer (Josh Mazerolle) didn't think I had enough work to do.. so he sent me a CAD drawing of plans for the rest of the cage..
98893
Mother in law was visiting for the weekend, needless to say I got a ton of work done in the shop. :smoke:
Got into bending the A-pillar bars
Slight 5* bend out with a 44* bend along the roofline
98894
98895
98896
Headliner bar has one 10* bend in the center
98897
98898
98899
98900
wfo guy
07-06-2014, 10:07 AM
I'm not excited about you using a Volvo but I like your work. :) Where did you get the idea for the braces on the chassis?
Mangohick
07-06-2014, 06:05 PM
Mission accomplished :)
I didn't design the chassis bracing.. matter of fact, the only thing I designed was the floor. The guy in the black hat designed it.. Mazerolle casserole or something..
Mangohick
08-21-2014, 08:34 PM
Haven't worked on my car in months.. got the spine finished up though.
101839
101838
101837
101840
101841
CruizinKev
08-22-2014, 03:46 AM
omg wow!!!! drool.
454bug
08-22-2014, 07:01 PM
Man, that is the wildest cage I have ever seen! AWESOME fab work! Very impressive! :1st:
I can't wait to see the finished product. Those big meats look great from the back!
Keep up the great work! :cheers:
Mangohick
08-25-2014, 11:36 AM
omg wow!!!! drool.
Thanks!
Thanks.. seriously though, your car bought me to this forum. You're breaking the mold set by all the GM bodied cars on here. Your bug is INSANE!
Tig
08-25-2014, 05:28 PM
Awesome progress, it looks great.
Mangohick
08-25-2014, 06:52 PM
Got the windscreen tubes fitted tonight
102031
102032
102033
102034
81sleepinOLDS
08-26-2014, 05:13 PM
This thing is awesome! I think it would be pretty cool to see a first gen s10 grill to match that gm power ;) great work. Definitely following this one!
Mangohick
08-26-2014, 08:30 PM
Got the harness bars in tonight.. time to start on the rear section. I only have about 24" between the rear tires :)
102058
102059
102060
Mangohick
09-02-2014, 10:58 AM
Started in on the door bars..
102276
102277
102278
k5warwagon
09-02-2014, 11:24 AM
Please please keep the manual sunroof! Also, how wide is the seat area? Looks very narrow between the "spine" and the door bar.
Don Volvo
09-02-2014, 03:14 PM
You can work on my Volvo Anytime.....
Mangohick
09-03-2014, 04:49 AM
I really wanted to keep the manual sunroof, but the roof of the cage is in the way.. There is very little room inside the car.. Just enough space for a seat.. I couldn't make it a clutch car if I wanted to, there isn't enough space for 3 pedals either.
What kinda Volvo do you have?
Mangohick
09-03-2014, 05:39 AM
102318
102319
Mangohick
09-04-2014, 05:06 AM
Got a couple more tubes in last night.. Two more tubes and the door bars will be done, then two roof bars and the "cage" will be done, then I can move on to the back or front suspension.
102366
102367
102368
102369
102370
Mangohick
09-12-2014, 06:17 AM
Got some goodies in this week
Wheel studs came in
102714
Wilwood hubs
102715
Speedway Mustang II/Pinto tubular IFS
102716
Parachute
102717
Finished up the door bars on the passenger side.. Looks SICK!
102718
no go nova
09-13-2014, 01:51 AM
Nice progress keep up the good work.
Mangohick
09-15-2014, 06:49 AM
Cage is "complete" for now..(still have roof bars and trans support to finish)
Moving on to front suspension..
102832
102831
102833
CampbellshotrodsAZ
09-15-2014, 09:00 AM
Wow, incredible work! Gonna be an awesome car!
Mangohick
09-15-2014, 11:35 AM
Thanks guys!
Mangohick
09-19-2014, 10:49 AM
Rotors are in.. just waiting on calipers.. Went with a Wilwood 6 piston setup for the front.
ARP hardware
103098
103099
12.19" x .81"
103100
103097
Mangohick
09-20-2014, 10:17 PM
Picked up a 6.0 for test fitting purposes.. Looks like it'll fit quite well with the 4L80E
103144
103145
103146
103147
103148
CadillacMazerolle
09-26-2014, 04:44 PM
You are killin it Vincent!!! I am very proud of you son!
Bob in St. Louis
10-01-2014, 04:28 PM
A Volvo? Dude, you're nuts, that's just crazy.
I just caught wind of this thread, and happen to work at a Volvo dealer.
I can't wait to get beck to work and show the guys in the shop what you're doing with a 242!
Rock on man.
Bob
Mangohick
10-10-2014, 06:40 AM
Thanks Pops!
Rock on man.
Bob
Thanks Bob!
Housing ends for the 9" came in today.. Decided to go with Mark Williams symmetrical "pro street" double row bearing ends with Timken bearings.
103881
Mangohick
10-27-2014, 07:16 AM
Havent touched the chassis in months.. finally got some time this weekend between Daddy duties to notch some tubes. I got the sub assembly for the coilover mounts made up.. then ran a couple 1.75" struts down to it from the top of the main hoop and two 1.65 supports from the sides of the main hoop. Crawling in and out of the car with the door bars in is a daunting task. Definitely took me about an hour and a half per tube.
104512
104513
104514
104515
104516
104517
104518
104519
no go nova
10-27-2014, 11:17 PM
Get this thing on four wheels.
Mangohick
10-30-2014, 05:53 AM
I sneak in a little fab time between changing diapers :)
I have a really good excuse for not working on my car as often..
104677
104678
Cant wait to get all this welded up..
104679
104680
104681
Bob in St. Louis
10-30-2014, 09:12 AM
Tell me honestly, you were sitting in the driver seat, bouncing her on your knee and making race car sounds. ;)
Mangohick
10-31-2014, 05:30 AM
There may or may not be a video of that happening on my girlfriends phone..
Bob in St. Louis
10-31-2014, 12:35 PM
HA HA....Understood. ;)
Mangohick
11-03-2014, 09:07 AM
Got the back subframe tacked in this weekend.. still have a few more tubes to add then it's on to the front suspension.
104777
104778
104779
104780
104781
driveit
11-03-2014, 11:08 AM
Awesome work. And looks like you might have a helper down the road.
nitroracer
11-10-2014, 04:34 PM
Out of curiosity, do you have more details on your other Volvo posted online anywhere? That one looks like an interesting build as well.
Mangohick
11-13-2014, 11:19 AM
I could definitely use some small hands sometimes!
Theres an album of pics here
https://www.facebook.com/MangoMoto/photos_stream?tab=photos_albums
Gil
11-13-2014, 01:03 PM
Congratz @ dad & mom, awesome work for both...
I was wondering where you sit to drive this crazy thing, I know now...
Very nice.
Gil
Mangohick
11-24-2014, 07:58 AM
Haven't had much time to work on my car, but I keep finding inspiration everywhere I look...
105643
105644
Mangohick
12-06-2014, 05:19 PM
:hammer:
106224
106225
106226
106227
106228
Mangohick
01-07-2015, 08:02 AM
Started working on the front section of the car. Made some sleeves to slide into the framerails at the firewall node. Then tacked 4 beads around each tube to space the frame halves together, so when it's welded up the two frame halves will be burned into the sleeve as well as each other. Started bending tubes for the upper a-arm mounts.
107368
107367
107369
107370
107371
107372
107373
107374
107375
Bob in St. Louis
01-07-2015, 06:19 PM
I love that last pic man, that's cool.
Mangohick
01-16-2015, 06:51 AM
Got the front frame rails lined up and tacked into place.
107661
107662
107663
107664
107665
no go nova
01-16-2015, 06:57 AM
Hey why not a motor plate and mid plate?
dangina
01-17-2015, 12:31 AM
the cage is turning out great!!!
Mangohick
01-19-2015, 08:29 AM
NoGoNova- Motor plate would take up too much front space where I could be running header tubes down low to the turbo. I plan to make motor mounts off the lower framerails that line up with the rear lower a-arm mounts and a crossmember in the same spot under the oil pan so the engine will be a structural member. Mid plate doesn't appeal to me as much because I'll most likely pull the engine and trans at once if either has to come out. Mostly for space reasons though..
Thanks Dangina!
Mangohick
04-21-2015, 11:37 AM
Finally getting some money to order parts and some time to get a few shop projects done as well as making a new turbo header for my street car. I ordered the front wheels 17x8.5 back in March from Weld so they should be in soon. I picked up a Mark Williams thirdmember and their splined quick release hub for the Sparco steering wheel I bought. Also grabbed a Sparco Grid race seat.. fits like a glove! I bought control arms from speedway motors, then changed my mind and decided to go adjustable, so I bought some threaded adapters and some rod ends and went to work with the TIG. I'm making the 4-link arms from .120" 1-1/2" DOM with 7/8 FK Rod ends.. that cost about 70 bucks each.. ugh. I decided to change gears with my transmission, pun intended... Instead of using a 4L80E with our custom CNC'd PCS 6 speed valve body I picked up a 6L80E from a Camaro so I can enjoy the benefits of a 4:1 first gear and .66 double overdrive.
In my spare time (hahahahahaha.. right) I've been having Chris Acors help me build a Fab9 housing from scratch.. Lets just say it's not as easy as it looks. Hopefully I'll have more progress pics soon!
4.56 Ring and pinion with a lightweight 35 spline steel spool in a 3.25" bore bolt through aluminum case.
111806
111817
111818
111819
111820
111821
111822
111823
111824
111816
111815
111807
111808
111809
111810
111811
111812
111813
111814
111825
19,69camaro
04-21-2015, 12:00 PM
Those are some serious parts! Looks good so far.
no go nova
04-21-2015, 08:42 PM
Good update glad to see your still doing this.
Mangohick
04-28-2015, 11:38 AM
Wheel porn!
Front wheels finally arrived.. 17x8.5 with 255/40/17 Nitto NT05's
112111
112112
112113
112114
Mangohick
04-29-2015, 10:43 AM
Front wheels look badass!
112172
112173
112174
112175
112176
Gil
04-29-2015, 11:12 AM
Awesome work !
JustJohn
04-29-2015, 11:16 AM
I still like the 240 series Volvo. Built and ran like tanks.
Mangohick
11-20-2015, 10:29 AM
Well.. I changed my mind again on my engine choice. Stuck up a killer deal on a 1JZ complete engine and a 2J GE block
119768
119769
119770
119771
119772
119773
119774
twosaturns
11-20-2015, 02:30 PM
just found this, friggin' awesome.
medici78
11-20-2015, 08:59 PM
Damn. This is a sick build. You can put any high-hp engine/trans combo in there and it will still turn out sick. Are you in Sweden?
Godbolt
11-21-2015, 01:57 AM
Love it. How much boost you planning to run? Turbo upgrade in the plans?
Mangohick
02-29-2016, 12:16 PM
Finally getting some time to work on my car again. Got some of the front frame braces tacked in and making progress on my FAB9.
Stumbled upon a good deal on a 2JZ-GE
124594
124593
124592
124591
124590
124589
124588
124587
124586
124582
124583
124584
124585
124580
124579
124581
Mangohick
07-04-2016, 07:53 PM
Finally got around to working on my car a little.. Been doing some kid stuff lately like making the little one a pedal tractor and lots of trips with her to the track! Got most of the tube work in the front done, time to hang suspension in the front. Then I got the headliner tubing in.. I put a 14* bend in my tube for a little more head clearance.. and most importantly, the sunroof crank still functions!
Gave up on the Fab9 because I warped the **** outta the faceplate.. Got a housing from Johns.. It's pretty beefy, and short.
Z06killinSBF
07-05-2016, 07:16 AM
This is awesome, looking good man
Mangohick
07-19-2016, 01:34 PM
Cut a few tubes for the front end and finished the headliner tubes. Getting an idea of where I want to mount the fire system and finishing up my adjustable caster mod for the MustangII lower control arms.
I have good help..
Martin71RS
07-20-2016, 11:59 AM
wow, great fab work! and a cute little helper :-)
StreetMachine82
10-25-2016, 07:09 PM
Beautiful work! Keep it up! Any new developments?
Project Bike Truck
07-05-2018, 01:17 PM
any updates on this killer car?
