View Full Version : Some Camaro progress today.
MuscleRodz
09-14-2005, 05:31 PM
I got my 3 link control arm jig over the weekend and I tig welded the first lower control arm together this afternoon. Lowers are fixed, and the upper will be adjustable. Rubicon jonny joint and Rubicon rubber joint for some compliance. I am quite happy how it turned out.
Mike
68protouring454
09-14-2005, 06:02 PM
i hate to burst a bubble but you better be dead on with your measurements or your rear axle will not be centered, its always good to have adjustment, or axle centerline will be screwed, having upper arm adjustment only mess's with pinion angle
goodluck
Travis B
09-15-2005, 05:43 AM
Nice jig, welds look good! Good luck
MuscleRodz
09-15-2005, 08:31 AM
goodluck
I know and I am already planning for that possibilty. I won't weld everything up until I have measured 100 times and then probably measure once more after that. I have a trick up my sleeve for very minor adjustments if need be.
Mike
F70t/a
09-15-2005, 02:54 PM
Look's great. I'm jealous :worship:
