View Full Version : Another quick project
astroracer
03-02-2014, 03:22 PM
I've had my hydraulic press sitting on these small HF trundle carts for a couple of years now. Makes it easy to move around. It's time to get it onto a dedicated cart.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-12.jpg
I used some more of that 2 x 2 tubing I used for the cut-off rack. I also had a couple of pieces left over from a couple of engine stands I repurposed into a chassis rotisserie.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-13.jpg
I ran the flap disc over the 2 x 2 after cutting them to length. All ready to square up and weld. It's a little smoky after a few minutes of welding. :)
https://static1.pt-content.com/images/pt/2014/03/ry3D400-14.jpg
https://static1.pt-content.com/images/pt/2014/03/ry3D400-15.jpg
The press has angle iron outriggers that keep it from tipping over. I will use these on the new cart. I'll cut them to length and weld them on.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-16.jpg
I wire brushed all of the welds and brushed on a coat of black Rustoleum.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-17.jpg
This will have to dry before I can put it all together. I plan to add a shelf on the cart to hold all of my press dies.
Motorcitydak
03-02-2014, 04:19 PM
I have similar plans but my thoughts are to just drill some holes at the ends of the angle iron and put in some all metal casters
astroracer
03-02-2014, 04:39 PM
Just keep in mind the angle iron will probably twist with the weight of the press on it. I wanted to add a shelf anyway so this was a good way to go.
Motorcitydak
03-02-2014, 04:44 PM
Very true, good thought. My work space is cramped so I like to have my large things on wheels so I can move them out of the way, mite get around to this one sooner or later
astroracer
03-02-2014, 05:48 PM
EVERYTHING in my shop is on casters!
Jetfixr320
03-03-2014, 07:10 PM
Nice project. Def like the idea to make the base a little bigger. Those things are top heavy.
astroracer
03-04-2014, 02:47 AM
Mine is usually loaded with two big press plates and a Swag bender. It IS heavy. Bolting it to the heavy base and then storing all of my press dies and blocks and what-not down on it will hopefully add some ballist to it. Should work well and be pretty stable.
Mark
astroracer
03-06-2014, 03:03 PM
Finally got out in the shop this afternoon to wrap up the press cart. Dragged the engine hoist in so I could lift the press high enough to get the cart under it.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-18.jpg
https://static1.pt-content.com/images/pt/2014/03/ry3D400-19.jpg
Lined up the bolt holes and put it together.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-20.jpg
Rolls around great! The way it feels I think it will even be good when it's loaded up with plates bending machines. I tried tipping it over and all it does is roll away.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-21.jpg
Jetfixr320
03-07-2014, 11:11 PM
Very nice!
astroracer
03-08-2014, 09:08 AM
Thanks! It turned great!
I have been pushing this thing all around the shop and it is almost impossible to tip it over. I probably could if I really tried but it rolls around nicely. Besides, the way I have it loaded up now, all of the weight is in the bottom so it is even better.
I wrapped up the cart build this morning. Cut a piece of 1/2" plywood and screwed it to the cart. I then screwed a 3 dollar yard sale tool box to it and loaded all of my dies, press plates and the Swag Bender on the bottom shelf.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-22.jpg
All of the press dies loaded in the box.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-23.jpg
The press plates all load in beside the tool box.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-24.jpg
The Swag Bender stores nicely in front of the tool box.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-25.jpg
This organizes ALL of my bending stuff into one spot and there is room for more in the box!
I also added a spring clamp tool holder for the jack handle to hang in.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-26.jpg
All done.
https://static1.pt-content.com/images/pt/2014/03/ry3D400-27.jpg
This is definitely a good thing and will keep all of this stuff in place so I don't have to go hunting for it.
Mark
Jetfixr320
03-08-2014, 06:48 PM
How do you like the Swag bender? I've thought about getting one.
astroracer
03-08-2014, 08:41 PM
The bender works GREAT! It went together easy and I have definitely gotten my moneys worth out of it. If you get one get the finger brake. I will be popping for the upgrade to mine in a couple of weeks.
Jetfixr320
03-09-2014, 07:52 PM
Ok, Thanks for the tip. I wasn't aware of that option.
airrj1
10-12-2014, 07:30 AM
Hey Mark,
Now that you have had the press on casters for a while, how do you like it? I know that you said that it moves well and isn't tippy, but how does it work when you are using it while it is on the casters? Just wonder if it moves around too much or if it is stable enough? I got my parts washer, weld bench, blast cabinet, and drill press up on casters, now I am eying up my press next. Thanks R.J.
astroracer
10-13-2014, 02:04 AM
Hey R.J.
The press works just as well as it did before it was mobile. All of the force is verticle anyway and working the jack handle doesn't apply enough force to move it. This thing had been sitting precariously on two furnture dollies for years with no problems so this was a better solution. Much more stable while moving and also providing room for storage.
Mark
airrj1
10-20-2014, 07:17 PM
I figured as much but it is good to hear first hand. Looks like I have an excuse to drag out the press and start resurrecting it this week.
