View Full Version : NEW LS serpentine drive solutions from Drive Junky
zschary
02-26-2014, 12:15 PM
These systems are designed just for the LS engine from the beginning. The components are top notch. Let us know what you think.. We have a High AC mount, and a low AC mount available now. We are working on other engines coming soon.. thank you
Zach
www.drivejunky.com for more info, or to contact us..
67machrod
02-26-2014, 05:06 PM
Zach,
The new high mount drive looks really good! I sent you an email. John
Bowtie racing
02-26-2014, 11:08 PM
I really like the low mount ac , and overall looks are better than compared to some others wich has too much "billet"
But why allways need for an new balancer? Make something wich would work with oem balancer, lots of crate engine bayers who would appreciate bolt on parts.
zschary
02-27-2014, 08:14 AM
Thanks for the comments.. and Bowtie Racing, the low mount works with the factory "truck" damper offset.. It was really the first higher end complete system built to do that.. we can sell them without the damper for use with truck and 2010 and later Camaro applications.. (which is the truck offset ) You can pick up those dampers for a song if your engine runs the vette or Camaro offset and we can save you a couple hundred.. We developed that specifically for those guys wanting to retain the factory damper, which is not a bad way to go.. Feel free to contact with questions..
thank you
Zach
Auto Rod Technologies
02-27-2014, 08:40 AM
Parts look really good!!
Damn True
02-27-2014, 08:46 AM
Hiya Zach,
I spoke to you a few months ago about the instrument panel in your car. Good to see you here.
zschary
02-27-2014, 06:04 PM
Yes. i remember.. thank you.. did you ever get that figured with your gauges?
1989GTA
02-27-2014, 06:26 PM
I like how compact things are. Makes engine swaps go a little easier.
Damn True
02-27-2014, 08:10 PM
I did. Another of our sponsors made a custom panel for me which came out great. I intend to show off his work a bit later on in my build thread.
To the point of this thread, as we discussed as well, a high mount, no AC variant is right up my alley.
....woops....some drunk mod accidentally hit edit rather than reply.
nvrdun69
03-01-2014, 10:55 AM
Any idea if the low mount ac would fit in the frame rails of an art Morrison front clip?
very nice I like the black one with the passenger side alt mount, wish you would have had that 12 months ago, I would have been customer #1
zschary
03-01-2014, 01:24 PM
We have yet to run into a fitiment issue, we designed the ac fit and ps fit to the engine with that in mind. also aftermarket frames are usually made to provide extra clearance down there over factory.. .. we can confirm for sure PM me or shoot me an email with any pics you want, I can also send some dimensions so we can figure it up front..
thank you
Zach
[email protected]
Dave95Z28
03-01-2014, 01:27 PM
If the factory system does, I would imagine their kit would with no problems. See the AME photo album below.
http://www.artmorrison.com/gallery/main.php?g2_itemId=1044
Dave
jwcarguy
03-02-2014, 09:48 AM
Zach,
It looks as it requires a different water pump as well
Is that your guys design?
Are there replacements available for the end user that may need to change in miles down the road?
Setup looks great!!
Thanks, Jeff
eric1967
03-02-2014, 02:26 PM
Zach,
Setup looks great!!
Thanks, Jeff
Looks like a truck water pump
jwcarguy
03-02-2014, 02:41 PM
It isn't a truck water pump, the outlet comes out the top at a angle
I am referring to the two piece housing and bolt on pulley ?
zschary
03-02-2014, 10:39 PM
That's right.. There are aftermarket water pumps with the bolt on flange available from a bunch of sellers.. We can provide it, edelbrock, prw etc.. it is a common flange to chevys.. Your right it exits forward unlike the truck design which goes up.. All based on GM pumps but with a press on chevy flange for our pulley. The custom parts, pulleys, brackets etc we cnc machine here on premises, and its built like a tank.
Cool Camaros by the way.. a 67 and a 68.. Makes me want to take my 68 out soon and get into some trouble.
option
03-03-2014, 08:37 AM
Wow am I ever glad I found this thread! I'll absolutely be contacting you for a full A/C delete system in black. What a gorgeous kit, nice work man.
zschary
03-04-2014, 08:22 PM
Thank you very much !!! .. Give a call when your ready...
zach
Hammons69
03-26-2014, 04:54 PM
Just got my drive junkie serpentine in black looks killer and fit perfectly in my f body
Carbo
03-26-2014, 08:09 PM
WOW, very nice. I may have to go this route instead of the stock GM setup.
dhutton
03-27-2014, 09:06 AM
Looks good. Is that a genuine Sanden compressor or a knock-off? I have noticed there seems to be a lot of knock-offs out there.
Hammons69
05-01-2014, 12:41 PM
94922
zschary
05-24-2014, 12:47 PM
WOW...
that car is looks incredible... Really great work on the engine bay.. The serp drive system looks really clean in there...
Send me some more pics when you get them... Great work One badass firebird...
Zach
Drive Junky
Aussie
04-26-2016, 12:52 AM
I'm now looking for a drive set up for my LS3 in to 70 Camaro with DSE subframe.
I do like the look of your system, but I would like low mount A/C compressor, but without notching subframe.
126541
Have you looked at low A/C mount option with alternator and power steer in same (driver side) position as per attached image?
Using a small Sanden compressor, could it be mounted forward on separate belt utilising a different crank pulley? Or could whole drive system spaced forward?
126543126542
zschary
04-26-2016, 08:15 AM
You wont have to notch the subframe but the alt needs to go on the pass side to make that system work.. the head is further back on the engine on that side allowing to run on the factory gm late model Camaro offset.. not sure why the alt would have to be moved, it is a one wire unit..
thank you
Zach
Aussie
04-26-2016, 09:37 AM
thank you
Zach
Purely aesthetic from my view
Do you have any images with low mount in a DSE subframe? or 1st or 2nd Gen Camaro.
So with the high mount set up the belt is further forward than the low mount. This would be a help to move compressor forward in low mount position if maintained position of alt & P/S on driver side. (hoping that makes sense).
IMPALAMAN1
04-26-2016, 11:22 AM
Zach, how would this system work with the procharger transplant kit? with the alt and ac on the passenger side? and the power steering on the driver side?
badazz81z28
12-16-2018, 10:47 AM
So this thread went dead...Are more people using this kit? It doesn't seem popular.
TonyV
12-17-2018, 03:27 PM
I'm currently in the process of switching to the Drive Junky set up with the high A/C mount....the other kit I had wouldn't hold up during track days. Bolts up nicely so far but because of my dry sump set up i'm waiting on a custom built bottom pulley. I chose the drive junky based on others using it and not having issues with belts coming off over 7K rpm. several months out to really put it to test.
TheCrucible
12-14-2022, 06:12 PM
204129
