View Full Version : 69 Tank In 68
jamesg602
09-14-2005, 01:04 AM
Will a 69camaro gas tank Fit in 68 camaro, What modifications are needed to make it fit? :help:
shoddy_f-body
09-14-2005, 06:17 AM
Pretty sure the filler neck location is different
68protouring454
09-14-2005, 07:11 AM
he knows that and is asking if the 69 (behind the license plate location) will work on a 68 with or without mods, that way he can smooth the tail panel or whatever else he had in mind.
i am not sure, but i would guess it would be pretty easy to make work, never compared the hole shape behind the license plate on 68-69, goodluck
jake
jamesg602
09-14-2005, 09:38 AM
68454protouring :idea:
Thanks I am looking into it more. Anyone else out there that has done this? I am going call DSE and get there input also .
ProdigyCustoms
09-14-2005, 05:08 PM
You will need to replace the back section of the trunk floor, or fabricate a filler hole cover in a humped shape.
jamesg602
09-14-2005, 11:35 PM
I appreciate the feed back, I am going for it just need to get tank for mock up and fabrication. Thanks again
z06fromhell
09-18-2005, 08:40 AM
james, im looking into doing the exact opposite. i want the filler cap in the tail panel. i have a good 69 tank that i would swap for a good 68 if interested. this would help us both out during the fab work. may be some other parts swapping to make this work we can help each other out with. let me know.....gene
jamesg602
09-18-2005, 02:33 PM
Gene the tank that I have is the original tank that came with the car. I now the tank I have doesn't leak, although it has had a pinhole repaired. As far as good, this tank would be just for mock up (IMO). I have been looking into the DSE stainless tanks but haven't been able to justify the price just yet. Are you looking for a new 68 tank for the final assembly and use ? I don't have the 69 tank yet, is your tank new? Do you plan on finishing with a stock style tank? Thanks for the reply I am looking forward to hearing back from you.
