View Full Version : 67' Camaro with 5th gen center console
Scruggs67
02-21-2014, 08:38 AM
Posted this on TeamCamaro forum, thought I would throw it up over here as well.
First off, I stole the idea from another member on here. So its definately not original. This was all done at home in the garage by me. I plan to use an e-brake handle that I aquired from a 2010 as well and remove the old pedal style ebrake.
I covered the console in vinyl to try and match the interior as much as possible. I didn't want a huge black plastic piece as a center console. I also tried to match the shape of the original gauge cluster out of a 67'. The only part I didnt do was spraying the paint. I left that up to the professional that originally painted the car. I had thoughts of going matte black instead of the car color but it just didnt look right to me. I used the traction contol button to run a b&m line lock, both aux sockets work along with the usb and aux input to the radio in the console box/storage. The shifter is the same b&m that I have in this picture, just a different knob and I used the shifter boot from the 5th gen.
https://static1.pt-content.com/images/noimg.gif[/URL ([URL]http://s970.photobucket.com/user/coastie428/media/2013-01-27_14-51-30_388.jpg.html)]
Sorry about the quality of some of pictures, I tried to get the best ones. Had to adjust a few as well so you can see all of it. Let me know what y'all think.
https://static1.pt-content.com/images/noimg.gif[/URL ([URL]http://s970.photobucket.com/user/coastie428/media/IMG_20140220_162323006_zps55c08ff2.jpg.html)]
https://static1.pt-content.com/images/noimg.gif[/URL ([URL]http://s970.photobucket.com/user/coastie428/media/IMG_20140220_163713775_zps4d70f8f5.jpg.html)]
https://static1.pt-content.com/images/noimg.gif[/URL ([URL]http://s970.photobucket.com/user/coastie428/media/IMG_20140220_162313710_zpsedac481c.jpg.html)]
https://static1.pt-content.com/images/noimg.gif[/URL ([URL]http://s970.photobucket.com/user/coastie428/media/IMG_20140220_163818968_zps7cc5076d.jpg.html)]
https://static1.pt-content.com/images/noimg.gif[/URL ([URL]http://s970.photobucket.com/user/coastie428/media/IMG_20140220_162158366_zps39421093.jpg.html)]
https://static1.pt-content.com/images/noimg.gif[/URL ([URL]http://s970.photobucket.com/user/coastie428/media/IMG_20140220_162223655_zps46c63a26.jpg.html)]
fast98
02-21-2014, 11:10 AM
Exactly what I want in mine! Nice job.
130fe
02-21-2014, 04:24 PM
Very nice, I have seen Jeff's (JWcarguy) console conversion and I have been trying to find one. Not many around on ebay, most of them are missing parts.
Scruggs67
02-24-2014, 06:20 AM
Thanks you. They do seem hard to find. I got this one off of ebay but the junkyard didnt even have a picture of it up. I had to inquire as to what all it included. I made sure it was everything that I need and bought it. It seems like the side pieces are the hardest to find.
jwcarguy
03-01-2014, 09:26 AM
Thanks!
I think that you are referring about my conversion?? ( since I have never seen one done prior to mine)
I like yours, great job!
Looks like a modern take on a 67' style gauge console
Chris,
I have a line on two Gen 5 consoles
I need one for a friend's 69' build and I will get you the info on the other one, once confirmed
69convt
03-01-2014, 10:43 AM
Nice work!! What steering wheel is that? Thx
jwcarguy
03-01-2014, 11:30 AM
Mine?? That is a Momo Retro wheel
Scott Atk
03-01-2014, 11:34 AM
Nice Work! I was also inspired by jwcarguy and acquired one a few months back. I'm also looking into making the 5th gen e-brake handle work if possible... keep us posted on that please.
jwcarguy
03-01-2014, 11:48 AM
Scott,
I have the E-brake handle assembly from mine if you need it?
It mounts off center and the first gen tunnel is much narrower, so I was going to make a "platform" that fits the side of the first gen tunnel and creates a "flat" area for the gen 5 E-brake handle assembly to mount to
then use either a Wilwood or Lokar dual e-brake cable setup that steps down to one point and mount/ connect to top of tunnel and route the cables to each side , and connect the e-brake switch to the gen 5 setup
For my, the handle was too "big and bulky" for my taste
so I made a template of the handle "hole" in the console, went to a buddy's shop and had him make a plate from 1/8" steel plate on the plasma table, filed don/ rounded the edges, welded two 8/32 studs to back and then had my upholstery guy wrap them in leather and make a "pouche" for my iphone
Only thing that I came up with, rather than just covering the whole, this way, it looks intentional and that I at least addressed the issue, rather than just covering it?
here is a pic
jwcarguy
03-01-2014, 11:50 AM
Scruggs,
How did you end up mounting your console?
69convt
03-01-2014, 01:51 PM
Yes, Thx what a way to cleanly update a classic. Tastefully done!
Scruggs67
03-11-2014, 09:11 AM
Sorry I have been on in a while, went on vacation.
jwcarguy; yes it was yours I was refering to. It looked like it flowed well in the car and made sense to go with a newer model like that, sort of keeping it in the family.
As far as the ebrake goes, I've put in there a couple times now and just looking at it, it seems way to big. If you google a 2010 camaro console in the car it looks like it sticks up too high and is a bit long. I think I am going to stick with the pedal for now, I think I am actually going to pull my console back out and fill in the ebrake hole and completely recover that side so its smooth. Might take a little more work but I think it would be worth it.
I ended up making some brackets to mount mine. I rested it on some peices of cardboard to figure out where I wanted it and then made some brackets that bolt to the floor and then the console screws onto the brackets. One bracket for the front where that cross piece sits under the shifter surround and one in the rear that bolts to the two bottom holes. I also made a center bracket which is just a piece of flat 1/4" aluminum that screws onto the console and then attaches to the megashifter where the old surround bolted. I got lucky with the center piece, it was all in the placement.
Scott Atk
03-11-2014, 01:02 PM
Scott,
here is a pic
Awesome! Thanks for the ideas. I have time to figure something out. I did buy a brake handle separately but appreciate the offer. We need to meet up sometime, I'm in Vegas... saw your car at Super Run, and decided then on the late model console.
KHShapiro
05-03-2014, 12:23 PM
Fantastic!
minendrews68
05-03-2014, 06:11 PM
Man, those really look good. My only problem is, I'm using a early model Hurst Super Shifter. The stick on this shifter is only about 6" long, and it mounts on the side of the Muncie 4 speed. Any one have any suggestions what to do there? Your set up is really nice looking!!
jwcarguy
05-03-2014, 10:33 PM
offset shifter handle
bad86ss
05-05-2014, 10:08 AM
I love it! I retrofitted a 73-81 Camaro console in my Monte. After some cleaning/dying/pinstripping it looks like it was made for the car
bad86ss
05-05-2014, 10:10 AM
This is what I got for $15
https://static1.pt-content.com/images/pt/2014/05/Screenshot_20140220210047_zpslcjiroy6-1.png (http://s1010.photobucket.com/user/bad86ss/media/86%20Monte%20Carlo%20SS/Screenshot_2014-02-20-21-00-47_zpslcjiroy6.png.html)
bad86ss
05-05-2014, 10:11 AM
This is what I ended up with about $30 and 3 hours later
https://static1.pt-content.com/images/pt/2014/05/1399541_10201935446139972_1955388262_o_z-1.jpeg (http://s1010.photobucket.com/user/bad86ss/media/86%20Monte%20Carlo%20SS/1399541_10201935446139972_1955388262_o_zpscxwkof4e .jpeg.html)
jwcarguy
05-05-2014, 03:54 PM
Very nice job!!
bad86ss
05-05-2014, 05:37 PM
Thanks man. That was my first rodeo with interiors!. Then I made seat brackets to mount those seats
WinMan
05-05-2014, 07:46 PM
Looking forward to seeing that 69 project's pictures. I get confused to how it should mate up to the 69 dash since it is not as seamless as the 67 and 68s
bad86ss
05-06-2014, 01:16 PM
How much was a 5th gen console? I bet it wasn't easy or cheap to get
Y-TRY
05-08-2014, 04:03 PM
Dudes, I love this idea. Those consoles look great! Where did you get the plastic inserts for around the gauges? (Carbon Fiber looking on JWcarguy, red on Scrugs) What did you do with the stock buttons/switches?
jwcarguy
05-08-2014, 05:54 PM
Mine is a combination of the factory Gen 5 Camaro "non-gauge" shifter bezel w/ tray and a Auto Meter 68-9 Camaro 2 1/16" gauge insert panel for a stock 68-9 console
a bunch of cutting, fitting and fiberglassing in
I removed the stock Gen 5 cig plug and traction control switch and filled them in and installed my two switches for the drivers and passenger seat heaters that I had installed when I had my upholstery redone
Then had a local company (Sin City Hydrograhics) do all my parts in a black "carbon fiber" hydro dip
Hope that helps Jeff
bad86ss
05-08-2014, 06:56 PM
Genius. Turned out perfectly
Y-TRY
06-10-2014, 12:15 PM
Okay, so I love this idea do much that I ran out and got a Gen5 console. Now I'm wondering how you guys made it look so good. Do you have more pics or a build thread?
The basic dimensions fit okay but the front of the console is much wider than the tunnel. Lifting the front up to tuck into the dash leaves a big gap under the console, between the console and tunnel. Did you guys modify your tunnel to fit or something?
It's looking like more than just fabbing brackets and basic trimming. There's not even really anything strong enough on the console to structurally attach brackets to. Looks like there's much more to this swap than it originally appears.
jwcarguy
06-10-2014, 12:30 PM
Pm me and I will tell you how to do it
Jeff
Y-TRY
06-10-2014, 04:25 PM
Thanks, JW. Tried to PM but your box is apparently full. Please PM me once you can get messages. Any tips/tricks/advice or step-by-step instructions would be appreciated.
Thanks, Nathan Y
jwcarguy
06-10-2014, 05:29 PM
Cleared pm box
Sorry
Tbarsch
07-08-2014, 02:50 PM
Jwcarguy, can you send me the info on installing this console too please? I just got a 2010 console because of this thread. Definitely needs some work up front to fit correctly.
Thanks in advance,
Tony
jwcarguy
07-08-2014, 04:14 PM
Thanks in advance,
Tony
Tony,
I sent you a pm with all the details
Jeff
130fe
07-08-2014, 04:32 PM
991359913699137I purchased one a while back and finally got it covered. Hope to try and install it in a few days. Hey Jeff, might need your expertise when I put it in.
C. Hayden
07-09-2014, 02:21 PM
I am doing the same in my 69. I am using a horseshoe shifter. Here is a picture of a 69 Camaro with a 2012 interior. I just plan on the console and shifter. Thanks for the idea Jeff.99201
Motown 454
07-09-2014, 09:08 PM
All you guys did an awesome job on these set ups. I'd love to put one in my 69. Jeff if your in a charitable mood I'd love some info on how you installed your . Awesome job guys.
jwcarguy
07-09-2014, 09:42 PM
send me a pm
It seems that I have been getting alot of pm's asking the same thing lately
Thanks, Jeff
Motown 454
07-10-2014, 06:18 AM
Thank you Jeff for all the help.
C. Hayden
send me a pm
Thanks, Jeff
Jeff do you have any pictures of the brackets you made or any other pictures you think might help us?
Thanks Craig:jump:
scott_fx
07-11-2014, 08:15 AM
991359913699137i purchased one a while back and finally got it covered. Hope to try and install it in a few days. Hey jeff, might need your expertise when i put it in.
whoa! Awesome
CROMAN69Z28
07-16-2014, 05:45 AM
What are you guys spending on these 5th gen consoles? What is a good source? eBay is limited right now.
130fe
07-16-2014, 06:14 AM
I got mine on ebay, they are hard to find complete. I looked for about 2 months before I found one, a lot of them are missing the side panels or other parts. I got lucky and ended up getting an complete auto console with gauges for $240 and sold the gauges for $200. It seemed like they vary in price from $150-300. Good luck with your search.
I purchased a manual insert for $40 and $50 for the shifter boot. I just had it recovered locally to match the original medium blue madrid vinyl and had a matching shifter boot (post above) for about $300, it would have been easier if my interior was black LOL Another cool feature is besides the 2 12v cig lighters, there is also a USB port that can be hooked up to your radio (if it has those capabilities).
A couple of installation notes- I ended up trimming the pass side panel (was originally the same length of the drivers side) because of my vintage air. I will end up make some brackets to attach it. Here is a picture of it completed.
scott_fx
07-16-2014, 07:42 AM
that looks amazing!
jwcarguy
07-16-2014, 04:40 PM
On average they are $200-350 depending on if it is the one with factory gauges, leather or plastic arm rest lid and condition
68metal
07-17-2014, 06:03 PM
HI ,
am I looking at a Gen 5 console in a 68 ?
WHat about the gauge cluster ?
Where did you get the carbon fiber looking trim piece around the gauge and shifter ?
I'm at the phase right now with my 68 and I really like what you did there.
jwcarguy
07-17-2014, 08:48 PM
HI ,
Thanks alot
The gauge panel/ shifter bezel, I made
started with a non gauge gen 5 shifter bezel
jwcarguy
07-17-2014, 08:50 PM
Looks great Chris!
Y-TRY
07-18-2014, 09:35 PM
Are the shifter plates interchangeable between auto and manual or are they specific?
jwcarguy
07-18-2014, 09:41 PM
Yes they are interchangeable
there are two different manual versions though, V6 and V8
kirt70camaro
07-19-2014, 05:21 AM
Thought this looks interesting.
http://www.youtube.com/watch?v=hnOD2oS4dio
https://www.facebook.com/g3carbon
jwcarguy
07-20-2014, 06:51 PM
I have this new 2 gauge insert available if anyone is interested
this is a brand new console gauge pod for a stock non gauge/ tray console car in silver finish
fits 2010-2014 Camaro
It fits two 2 1/16" aftermarket gauges (ie Auto Meter, etc) that are angled for better viewing, much better than the other brand offered that positions the gauges straight
easily attaches with 3M double sided tape (included)
has one slight smudge in back of one pod , hard to see, even when installed
Asking $60 shipped
Robsutt
07-27-2014, 07:29 AM
Which T56 trans fit this mod in a 1st gen? Have seen that cady, gto, etc have different shifter positions.
jwcarguy
07-27-2014, 07:55 AM
Mine is a LS/F-body T56 with offset shifter handle
Jeff
Tapsexpress
09-02-2014, 06:27 PM
JW is this still available? I am looking into retro fitting into my second gen. I like what you did and I am presently looking for a donor console.
Appling Prostreet
10-27-2014, 08:27 PM
Subscribed
Appling Prostreet
10-28-2014, 05:14 PM
anybody else know any details about this car. would love more pics and perhaps owners/builders contact info. I have a complete 2011 SS im trying to put in a 67(running gear and interior). This pic definitely gives me inspiration.
Stan68
10-29-2014, 05:49 AM
I would love your advice and tips on installation. I have the gauges finished and ready to start on the console now.
medbali76
05-01-2015, 09:49 AM
I am wondering if it would be possible to install this console into my 72 Nova. I have just purchased a 2014 ZL1 console so now I have to give a try for sure. :)
You guys made an awsome job. I hope I can get the look I want.
jwcarguy
05-01-2015, 10:22 AM
anything is possible!1
Just take your time in both the placement and any trimming
also plan well with its relationship with other parts (ie shifter, ac vents, seats, etc. etc.)
medbali76
05-01-2015, 10:28 AM
:twothumbs
Will do, thanks
minendrews68
06-27-2015, 06:20 PM
Thanks!
Chris,
Jeff,
Looking at your interior looks just like mine. I will have to admit I copied the way you did your radio. I don't have my carpet in yet either. I like the late model console, just have to work out the offset shifter. I made a console out of walnut, but I like the one you have, to me it fits better.
130fe
06-28-2015, 02:30 PM
Carl, here is a picture of the 3/8 steel that I used the position the shifter forward (per your post over at Lat-G). On my installation, the shifter comes through the floor just about 1 inch forward of the cup holders.
jwcarguy
06-28-2015, 03:19 PM
Chris, copied what I had to make on my setup, but while having the bracket made to relocated handle forward, he also, raised the mounting location also
Jeff
minendrews68
06-28-2015, 05:14 PM
Since my shifter sits on the left side of the trans, I would have to have somewhat of a "L" shaped bracket. I think I'm going to have to give this some thought,
minendrews68
06-28-2015, 05:19 PM
Jeff, did you make the shifter handle? It really looks good. I had drawn up some ideas of slapper bar traction bars made out of solid 1.5" x 2.5" solid aluminum, that I think would look pretty cool, just haven't researched it enough to make them. I'm wondering if the aluminum would hold up to bending.
130fe
06-28-2015, 06:35 PM
Carl, the part was made by a mutual friend of Jeff and I. Are you using the GTO trans? Trying to picture what application had the shifter on the left side.
minendrews68
06-28-2015, 06:50 PM
The transmission is a Muncie M-22. The shifter bolts to the left side of the tail shaft, and comes straight up.
terryt
07-12-2015, 04:03 PM
Love that interior. Do u know who did the work?
medbali76
10-31-2015, 10:44 AM
Well, it fits the 72 Nova perfectly. No trimming at all. The 4 pod gauge was removed and used the basic cover with the tray.
Everything works, lights for the shift positions, handbrake, cigarette lighters all work. Pertty cool :-)
118963
118964
118965
I am thinking to buy the Hurst assembly to get an even cooler look.
Motown 454
10-31-2015, 11:36 AM
medbali76 I need the details on your install! Did you make a hole the size of the shifter gasket? I have the same set up to go in my 69 Camaro with a 4l85. I already bought the Hurst set up. It looks great in there.
medbali76
10-31-2015, 01:17 PM
It was installed by the shop who made the engine swap.
There are pics but those do not show everything.
Right now I am working abroad. As soon as I get home and pick up the car I will get the details.
130fe
10-31-2015, 01:43 PM
Medbali76, that interior is looking good! Nice install on the console with the auto shifter.
medbali76
10-31-2015, 02:22 PM
Thank you.
Actually there are plenty of small things that still needs to be done to look perfect. The interior panels and seats were grabbed from different cars so there are a lot of colors now inside.
It looks better on pics.
118988
Motown 454
10-31-2015, 08:14 PM
Medbali76 Thank you ! I was wondering if the hole in the floor needs to be as big as the 5th gen uses, I think its to accommodate the T56 and the auto in the same package. What are the seats out of ?
medbali76
11-01-2015, 06:42 AM
I am pretty sure that they did not cut that big. And they actually made a modification for the shifting mechanism. They connected the transmission and the shifter with cable.
They had to do this to be able to move the consol to the best position. They also prepared strong brackets that holding the shifter and the whole center consol.
This is a 6l90e tranny so they had to enlarge the transmission tunel too. I will send pics to your email address.
The seats are from a Mitsubishi Lancer Evo lX.
408maro
11-02-2015, 09:51 AM
great pics and install guys.
I have a 5th gen console I have for my 72' Camaro with a T-56 and trying to get ideas on how to mount it.
where on the center console did you mount it?
is their bracket spots on the console that you used or made your own mounting points on the console?
minendrews68
11-04-2015, 07:18 PM
Well, now back to the drawing board... Just converted my Camaro to a T-56 6 speed. Now the 5th gen console is back on the table of "I wants".
PLCamaro
05-14-2016, 07:53 PM
Was reading this forum, I too, want to install a 5th gen dash in a 69 camaro. Can you send me as well how you did this?
130fe
05-15-2016, 03:25 AM
PL, here is my install thread- https://www.pro-touring.com/threads/110357-5th-gen-camaro-console-install-in-a-first-gen?highlight=console
MAGONSTERZ68
05-15-2016, 05:06 PM
Nova dash and consol looks killer!
definitely a to do on next build. Currently have this set up, like the slap shifter with brass knuckles set up but had to mod the tunnel to accept ratchet assembly mechanism. The wifey bought me the center consol a few Christmass ago finally got around to installing.
Tpichevy
08-01-2016, 09:10 PM
Anyways to get the pics back on the first page to show up? I can't see them....
jaycoy65
08-09-2016, 11:06 PM
Anyway u could make me one of them pouches? If so how much?
tjaymoyer
03-04-2017, 06:01 PM
Where did you get the center piece with the gauges? Is this aftermarket or custom?
jwcarguy
03-04-2017, 06:22 PM
which one are you referring to? mine or Sruggs67
Thanks, Jeff
Joey52
08-18-2018, 07:00 AM
Jeff
Can you share the info with me on how to make it fit properly. i saw one with a BM stealth shifter that was slick
jwcarguy
08-21-2018, 03:54 AM
PM me
giggs357
11-28-2018, 05:00 AM
Thanks!
Chris,
What seats are those that you used for the front and rear? In the pictures that were attached to this post that is
dirt2mud
07-07-2020, 01:13 PM
Scruggs,
Can you send me Pics of your console install? The links on your post seem to be broke.
I would like to see what yours look like compared to jwcarguy.
Thanks.
[email protected]
67CamaroLSX
12-29-2020, 02:53 PM
What seats are you guys using. I have the Procar Elite seats in mine and they are a little too wide. They push in on the sides of the panels.
Truckie707
01-11-2021, 07:21 PM
did you ever do this ? I wanna do the same just center with horseshoe shifter . If you did very curious what you used
Orngcrush69
01-21-2021, 06:50 PM
Has anyone been able to use the 5th gen e brake with a '68?
jwcarguy
01-24-2021, 08:19 AM
Yes, make mount for tunnel and use the Wilwwod dual e-brake cabke kit to connect it
Smooth67
01-29-2021, 06:21 AM
Jeff, Does this look like the one https://www.jegs.com/i/Wilwood/950/330-9371/10002/-1 or is there one with shorter cables?
slimjim
01-29-2021, 04:45 PM
That one would likely work, I used the Lokar version (https://www.jegs.com/i/Lokar/625/EC-80FU/10002/-1)
jwcarguy
01-29-2021, 05:39 PM
Brett, yes, or the Lokar one mentioned also
Jay68
04-02-2023, 08:57 AM
Hi I was looking to do this in my 68 before I buy one do u have any pics of how u mounted it etc or brackets u made because the way u have it in there looks awesome and see less and I don’t want to hack one Tia jay
Jay68
04-02-2023, 09:48 AM
That looks awesome like it came from the factory going to attempt this in my 68 what did you do for brackets?
srode
04-02-2023, 12:23 PM
118963
118964
118965
Anyone know what display is this is in the dash for gauges etc?
Jay68
04-16-2023, 12:29 PM
Hi I’m currently trying this in my 68 firebird but not fitting quite the way I’d like it any tips or tricks would be awesome… jwcarguy send help fast please
jwcarguy
04-16-2023, 04:20 PM
send me a text, I can reply with a few pics and dimensions
srode
02-07-2024, 01:19 AM
Picked up a nice 5th gen console for our build, curious what seats people are using for this in a first Gen to avoid rubbing, looks like factory seats are too wide.
send me a text, I can reply with a few pics and dimensionsSent a message for some pictures and dimensions too.
XLexusTech
02-07-2024, 03:30 AM
hi guys not to derail the thred but if anyone is interested in a mint black console I have one. I was going to go the console route then bought a really sweet billet shifter boot cover.
beyonda68
08-17-2025, 11:36 AM
Does anyone have more info on this car with the horse shoe shifter and that 5th gen console? Thanks in advance.
JB68RS
03-13-2026, 07:27 AM
so I have mine in and working on a Trans swap from TH400 to T56 Mag - and now I need a working E-brake - anyone have info on a working e-brake for this center console ty
Scott Atk
03-13-2026, 05:45 PM
Probably not for everyone but I used a 2" stroke linear actuator for parking brake, works good
https://www.youtube.com/watch?v=aWzaXXx5aZc
Wiggins67Camaro
03-17-2026, 07:35 AM
Thanks!
Chris,
I know it’s been awhile but do you still have the info for installing the 5th gen console if so could you send it to me. Thank you a lot!!
srode
03-22-2026, 01:50 AM
Find the brake lever in a car that's being parted out and get it and cut out the floorboard section it bolts too and it will be easier to mount it. Also make sure you get the full cable and tube with the ball end and the part that hooks it to the 2 brake cables going back. Then use the willwood cable set or the one from Lokar mentioned above.
