View Full Version : 73 Firebird build by Screamin' Performance
67speedfreak
02-11-2014, 07:03 PM
Here is a 73 Firebird we are doing for a customer. It will be getting the pro-touring treatment !
https://static1.pt-content.com/images/pt/2014/02/IMG_0386JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/02/IMG_0387JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/02/IMG_0391JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/02/IMG_0393JPG-1.jpg
67speedfreak
02-11-2014, 07:09 PM
Tear down.
https://static1.pt-content.com/images/pt/2014/02/IMG_0400JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/02/IMG_0445JPG-1.jpg
Sub frame painted and new suspension going on.
https://static1.pt-content.com/images/pt/2014/02/IMG_0587JPG-1.jpg
Body shell stripped and ready for media blast !
https://static1.pt-content.com/images/pt/2014/02/IMG_0604JPG-1.jpg
Dave B
02-11-2014, 07:59 PM
Looks like it was "Rockford Files" brown.
JoeyP
02-13-2014, 04:55 AM
Wow looks good, making a lot of progress.
67speedfreak
02-13-2014, 08:55 PM
What's up Joey P ! :)
67speedfreak
10-01-2014, 06:18 AM
Update.
Floor is out. firewall has been smoothed. Roof has been replaced as well as upper cowl.
Starting on mini tub.
https://static1.pt-content.com/images/pt/2014/10/IMG_0917JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/10/IMG_0939JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/10/IMG_0984JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/10/IMG_1042JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/10/IMG_1043JPG-1.jpg
67speedfreak
11-08-2015, 08:14 AM
CampbellshotrodsAZ
11-08-2015, 10:31 AM
Very nice! What are the specs on the rear wheels?
67speedfreak
11-13-2015, 07:26 AM
They are 18x12 w/ 335 rubber. I will have to look up the specs.
67speedfreak
67speedfreak
11-13-2015, 07:29 AM
67speedfreak
11-13-2015, 07:32 AM
67speedfreak
11-13-2015, 07:37 AM
67speedfreak
11-13-2015, 07:39 AM
67speedfreak
11-13-2015, 07:43 AM
67speedfreak
11-13-2015, 07:49 AM
Josh@Ridetech
11-13-2015, 07:53 AM
Looks good!
AtomicFirebird
11-13-2015, 10:06 AM
119549
Ripper
11-15-2015, 10:30 AM
Great sheet metal skills!
F-Body International
11-15-2015, 10:34 AM
x2...definitely agree on this!
Rag-Rat
11-16-2015, 09:35 AM
I'm fortunate to live close enough and have had Brian do some work for me and get to see this car and others up close. Its hard to find someone with his skill level. Top Notch !!!
67speedfreak
11-16-2015, 10:13 AM
Thanks for the compliment guys ! Chris, always a pleasure !
67speedfreak
12-02-2015, 05:02 PM
Here are a couple updated pictures. We got the dash, tulips and trunk sprayed satin black now we can install the subframe and suspension.
CampbellshotrodsAZ
12-03-2015, 12:20 PM
Very nice! If you don't mind my asking, what are your front wheel specs, sizewise?
kamaro
12-07-2015, 09:48 PM
Thats almost the same setup I'm using in my '71 Formula, the Chassisworks suspension parts were a good choice in terms of functionality and fit, except that the ride height in the rear is too much for my taste, I got the suspention in the absolute minimum height and still there is at least 2.5 in. of clearance between the finder lip and the tire (using 26 in. tires). Unfortunately, and after many calls to CA Chassisworks, they told I have to just live with it!.
NOT A TA
12-08-2015, 09:17 AM
Good looking build! I don't see any trim studs around the windshield opening. Are you using flush mounted glass?
67speedfreak
12-08-2015, 09:16 PM
Thanks,fronts are 18x9 275s
67speedfreak
12-08-2015, 09:17 PM
I agree, that's why I modded the upper shock crossmember and gained an extra 2 in.
67speedfreak
12-08-2015, 09:19 PM
Thanks, No flush mounted glass, We will add the studs later, replacement parts don't come with them.
67speedfreak
12-08-2015, 09:23 PM
We got the rearend and suspension in the Firebird today. The rear is sitting several inches higher than ride height because there is not weight in the car.
kamaro
12-09-2015, 12:34 AM
Is it possible to snap a photo of that mod? I thought about modifying the upper crossmember but getting the upper shock mounts inwards a bit more to lose 1 or 1.5 in of ground clearance.
67speedfreak
12-09-2015, 07:32 AM
Here is a pic of the mod. I just cut out the existing crossmember and added my own round tube crossmember.It is pushed up against the floor.
rohrt
12-09-2015, 09:45 AM
pretty sweet!
67speedfreak
01-02-2017, 07:34 AM
Here are some current pictures of the project. Project is currently back home with the customer awaiting drive train.
