quarterbooty
02-01-2014, 07:38 PM
I finally pulled the trigger on an LS motor, so I now have a 383 SBC for sale. I’m offering the engine complete from oil pan to carburetor including ignition and accessories. I built the engine in 2005, and it has approximately 8000 miles on it since. The car was stuck in paint jail for nearly two years from late 2006 to 2008. It was also on jack stands for most of the 2010 and 2013 seasons while I waited for wheels to be manufactured (both times). It makes excellent power, is extremely reliable, doesn’t burn oil, and sounds killer. High quality parts have been used throughout. Highlights of the major components are provided below.
The short block is based off of a late-model GM block with roller cam provisions, a one-piece rear main seal, and four-bolt mains. All machine work was performed by JD Engine & Machine in Columbia, MO. The rotating assembly is a forged 4340 Eagle crank and H-beam rods, and flat-top SRP pistons (4.020” bore). Cylinder heads are AFR 195 Eliminators with straight plugs and 65cc combustion chambers; the heads were purchased and installed in 2008. Static compression is 11:1, and it runs just fine on 91 octane due to the cam. ARP fasteners are used throughout, and external fasteners are stainless steel.
The cam is a custom Comp hydraulic roller ground on XFI lobes. Duration at 0.050 is 242°/248° and valve lift is 0.584"/0.579" (with 1.6 rockers) on a 110° LSA. Lifters are Comp Cams Magnum series. An AFR Hydra-Rev kit helps prevent valve float at high RPM. It idles at 800 RPM with a choppy lope, but still has great street manners. I can lock the torque converter up on the highway at 2200 RPM and cruise with no bucking or surging.
Ignition is all MSD including the distributor (mechanical advance only), Digital 6AL box, and Blaster 2 coil. Plug wires are black Taylor ThunderVolt 50s.
Fuel delivery is from a 750 CFM Holley HP carburetor with mechanical secondaries. There is no provision for a choke, but it starts right up after two pumps of the pedal. I tuned the carb with an Innovate Motorsports LM-1 wideband air/fuel ratio meter. The fuel curve is spot on with no off-idle or part-throttle stumlbes. WOT will pull down to 12.5:1 for maximum power, while cruise is in the upper 14:1 range with no surging. I can provide the buyer with my LM-1 tuning logs if interested. This engine is literally ready to drop in and drive with zero tuning required.
The front accessory drive is a black hard-coated Vintage Air Frontrunner and includes A/C, power steering, and a 140 amp alternator. This is the best engineered serpentine system you can buy. The power steering pump is currently setup for an external reservoir (not included), but an integral plastic reservoir could easily be added (also not included). A list of all parts used in the engine and included in the sale is provided below. Note that the part numbers correspond to Summit Racing unless noted otherwise.
Short Block
Rotating Assembly - ESP-12111020
TCI Rattler 2000 (6.29”) - TCI-870001
Pioneer SFI 29.1 Flexplate - PIO-871010
Heads
AFR 195 Eliminator (65cc chamber, straight plug) - AFR-1034
Intake
Edelbrock RPM Air Gap - EDL-7501
Valve Train
Comp Cams Custom Hydraulic Roller (242°/248° 0.584"/0.579" on a 110° LSA) - N/A
Comp Cams Pro Magnum Lifters - CCA-875-16
Comp Cams Pro Magnum Rockers (1.6 ratio) - CCA-1302-16
Comp Cams Hi-Tech Pushrods - CCA-7940-16
Cloyes Double Roller Timing Chain - CLO-9-3145
AFR Hydra-Rev Kit - AFR-6155
Oil System
Milodon Oil Pan - MIL-30909
Milodon Pickup - MIL-18314
Melling High Volume Pump - MEL-M55HV
ARP Oil Pump Shaft - ARP-134-7901
Fuel Delivery
Holley 750 CFM HP Carburetor - HLY-0-80528-1
1/2" 4-Hole Phenolic Spacer - SUM-G1402
-08 AN Stainless Steel Braided Distribution Line
Fasteners
ARP Stainless Steel Fastener Kit - ARP-534-9601
ARP Dampener Bolt - ARP-234-2501
ARP Flexplate Bolts - ARP-100-2901
ARP Cam Bolts - ARP-134-1001
ARP Oil Pump Stud - ARP-230-7003
ARP Carb Studs - ARP-400-2401
ARP Starter Bolts - ARP-430-3502
ARP Main Studs - ARP-134-5601
ARP Head Bolts - ARP-134-3601
ARP Rocker Studs - ARP-134-7104
ARP Valve Cover Studs - ARP-434-7609
Gaskets
Fel-Pro Head Gasket - FEL-1003
Fel-Pro Intake Gaskets - FEL-1255
Fel-Pro Oil Pan Gasket - FEL-1886
Fel-Pro Valve Cover Gasket - FEL-1628
Ignition
MSD Pro-Billet Distributor - MSD-85551
MSD Digital 6AL - MSD-6425
MSD Blaster 2 Coil - MSD-8202
Taylor ThunderVolt 50 10.4 mm Wires - TAY-98051
Taylor Space Age Boot Protectors - TAY-2410
Accessories
Comp Cams 2 Piece Billet Timing Cover - CCA-210
CSR Distributor Hold-Down Clamp - CSI-670C
CSR Thermostat Housing - CSI-912C
CSR Fuel Pump Block Off Plate - CSI-660C
GM Cast Aluminum Valve Covers - NAL-10185064
Earl's Billet Aluminum Breather - EAR-3434112ERL
Jegs Maxi Prostart'r - 555-10040
Vintage Air Front Runner - VTA-174008
I plan to keep the engine in the car for the short-term to allow interested buyers to witness the engine start and run. I strongly prefer local pick-up, but if shipping is necessary I am open to discuss. The engine is located in Leawood, KS (suburb of Kansas City).
Cost
Complete Engine Including Accessory Drive - $6200
Complete Engine NOT Including Accessory Drive* - $5200
*If you do not want the Frontrunner, I have a Weiand high volume aluminum water pump that I will install for the indicated price.
This is a fantastic deal on a high-quality engine. If you price out everything included it would cost over $12,000 to replicate. Please don’t hesitate to reply or contact me with any questions. I have additional build pictures, and I can easily get a photo of a feature that you’re interested in. Thanks for looking.
https://static1.pt-content.com/images/pt/2014/02/IMG_2384JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/02/IMG_0336JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/02/IMG_2397JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/02/IMG_2394JPG-1.jpg
Short Block
Heads
Intake
Valve Train
Oil System
Fuel Delivery
Fasteners
Gaskets
Ignition
Accessories
Cost
