jeffandre
09-12-2005, 03:03 AM
Let me know what you think of what I did on my 71 Camaro. I wouldn't normally go through this much trouble but since I had to custom machine my Del-a-lum's to fit my Vette Brakes control arms I went ahead and applied a little critical thinking to the process first. I setup the UCA bushings both on the crossshaft as well as within the arm holes to position the upper arm rearward about 1/4". I also setup the LCA bushings within the arms to position them forward about 1/8". I am guesstimating about 1.5 degrees of increased caster just by doing this (maybe more?).
Of course I could have drilled and relocated my upper arms but a few things kept me from doing that. One, the big tires are already back far enough at full stop, so hopefully moving the LCA's forward a bit will help keep the ties relatively centered within the wheel opening. And two, I had to machine and custom tweak the bushings anyway so it really wasn't that much extra work. Anyway, let me know what you think! Good idea? Bad? If bad, why? Thanks,
