View Full Version : Bruisr - 1968 Camaro
redefined
01-29-2014, 02:59 PM
Yup I know Bruisr isn't spelled correctly, but hey it was the only available plate option here! Ha!
When I purchased this car it was exactly what I wanted. A running, driving, decently modified car! I wanted something I could buy and drive day 1 while picking up mods along the way to get it how I wanted it. So for this purchase, mission accomplished.
I quickly decided I wanted to go fuel injection with an LS swap so that's what everything will be based around. The use of this car will be street, autocross, and road courses (everything from HPDE's to time attacks). The only time it'll see the drag strip is when I go to just hang out with everyone else. Sure I'll probably do a few passes but nothing crazy, not setting the car up for that.
Car as it sits now:
Eldelbrock TEC 200 Aluminum Heads
COMP Cam 12-612-5 Solid Lifter Cam
Roller Rockers
Ceramic Coated Headers
Holley Competition 750 cfm
MSD Ignition
Super T10 4 Speed Transmission
Center Force Clutch
8.5 10 bolt posi 3.73 from 81 WS6
Aluminum rear support cover
Subframe connectors
QA1 Adjustable Aluminum shocks
6pt Custom roll cage
Hotchiks 2" drop leafs and Coilovers
Hilwig 1 1/8" front sway bar
Quick ratio 12.7:1 power steering box IROC HX box aka hot OEM setup
All new suspension & body bushings
Front & Rear LS1 Disc Brakes w/ Hawk pads
BMW Parallel wheels 18x8.5/9.5
Autometer Tach & Speedo
OEM Forged Crank
OEM polished rods
TRW pistons w/ floated wrist pins
Balanced rotating assembly
ARP Head Bolts & Fasteners
Scatter Shield
Kenwood stereo and amp
Redone interior
https://static1.pt-content.com/images/pt/2013/09/9718570417_602c52198e_b-1.jpg
https://static1.pt-content.com/images/pt/2013/09/9718570163_8b71d96e15_b-1.jpg
https://static1.pt-content.com/images/pt/2014/01/9718569753_ae62174876_b-1.jpg
https://static1.pt-content.com/images/pt/2013/09/9718569547_99fcf6463b_b-1.jpg
redefined
01-29-2014, 03:00 PM
I found a local LQ4 for sale so I decided to pick it up. My goal is to go boost with this, wasn't set on turbo or supercharger at this point, so I figured this would be a good start.
I took my wagon and drove 1.5hr to pick her up. 2005 with 64k miles
https://static1.pt-content.com/images/pt/2014/01/IMG_0177JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/01/IMG_0183JPG-1.jpg
After speaking with an engine builder he's confirmed my thoughts of going aluminum. He knows my driving ability and even currently races with me in on the karting scene. He says I'll for sure notice the weight difference on the front of the car, welp that was short lived! Out with the LQ and in with an LS! I tossed up a FS/FT thread and came across someone who was looking for an iron block and currently has an aluminum LS6, woot! We are currently in the process of working out shipping but we're trading short blocks.
I plan to still use my 317 heads and toss some parts in them, not sure what yet. I'll want to go with a custom cam for boost and of course some springs as 7500rpm is desirable for me. It's current disassembled but I think that'll be fine as a stroker kit is in my future.
https://static1.pt-content.com/images/pt/2014/01/YvMT_mdULSORSy6wyFVbdDuNsQS2TgmVfiHQjlSn-1.jpg
redefined
01-29-2014, 03:01 PM
So what are my plans? LS swap, supercharger, upgrade rear end suspension, possible aftermarket front subframe at some point and I'm leaning towards leaving manual brakes vs swapping to power. Anyway I've seen a ton of build threads and people don't seem to list specific parts. I'm going to try and list a part number and link to what I'm planning on using. If you have any opinions as to why I shouldn't use what I've listed, or have better parts that I should use then by all means let me know! I'm new to the LS world and to muscle cars in general!
My LQ4 didn't come with an ECU or harness so keep that in mind. The LS6 is just a short block so no ECU/harness with it either. Below are the motor parts I’m leaning towards. After speaking with my engine builder and Texas-Speed it’s agreed that the 10:1 range is where we’ll want to be, going supercharger too. So this setup is trying to create this. I know Texas-Speed offers a stroker kit, just trying to list out part numbers here. The internals should be a 383 stroker setup, correct me if I'm wrong.
Oil Pan – Holley Part # 302-2 (http://holley.com/302-2.asp)
Callies Compstar 4.00” Crank – Part # 186-4.00Crank (http://www.texas-speed.com/p-480-callies-400-stroke-lsx-crankshaft.aspx)
Callies Compstar 6.125” H-beam Rods – Part # 186-CsC6125DS2A2AH(http://www.texas-speed.com/p-421-callies-compstar-6125-ls1-h-beam-connecting-rods.aspx)
Wiesco -8cc 3.905 Forged Piston – Part # 10-K394F (http://www.texas-speed.com/p-1283-wiseco-8cc-3903-4030-dished-forged-piston-set.aspx) & Wiesco Rings
Main & Rod Bearings – Not sure?
Full ARP Studs/Bolds - Trying to find part #
Head Gaskets - .040 thickness – Can’t find Part #
Hooker Headers - Part # 2276-7HKR (http://www.holley.com/2276-7HKR.asp)
Exhaust - No clue, custom maybe?
Supercharger – Procharger, not sure which one yet.
Head/parts – Undecided on specifics (7500rpm wanted) Current heads are 317's
Cam – Custom grind not sure from whom yet
More parts for the swap and other upgrades:
Engine Mounts – Holley Part #12618HKR (http://holley.com/12618HKR.asp)
Transmission Crossmember – Part # 12626HKR (http://holley.com/12626HKR.asp)
Transmission Mount – Prothane 7-1604 (http://www.summitracing.com/parts/ptp-7-1604-bl)
DSE Narrowed Fuel Tank – Part # 080105 (http://detroitspeed.com/1967-1969-F-Body-products/080101-fuel-tanks.html **Email sent to Ricks to get info on a tank setup**)
DSE Mini-Tubs – Part # 040401 (http://detroitspeed.com/1967-1969-F-Body-products/040401-deep-tubs.html)
DSE Quadralink Rear Suspension – Part # 041703D (http://detroitspeed.com/1967-1969-F-Body-products/041703-QUADRALink.html)
DSE Axle/Upgrades - Undecided but need a new diff for sure
Harness: PSI PN HAR-103 - http://secure.ultracart.com/catalog/PSI/STANDALONE-HARNESSES/LS-Harnesses-24x/HAR-1013.html
ECU/PCM: PSI PN PCM-1003 - http://secure.ultracart.com/catalog/PSI/PCM-PROGRAMMING/Vortec-PCM-Programming/PCM-1003.html
ECU/PCM Mount: PSI PN ACC-1030 - http://secure.ultracart.com/catalog/PSI/PCM-PROGRAMMING/Vortec-PCM-Programming/ACC-1030.html
HP Tuners Pro: PSI PN 6021 - http://secure.ultracart.com/catalog/PSI/PCM-PROGRAMMING/HP-TUNERS/6021.html
For parts where there are no Part #'s or I'm undecided again feel free to make suggestions. However, if you do please back it up with a reason and a link if possible!
An engine builder will do my machine work and assemble the short block and I'm no welder so mini-tubs will have to be done by someone else as well. I plan on doing most other things myself or with anyone willing to help.
Thankfully my wife is into cars as well and loves muscle cars. She actually pushed me to pick this car up, yesss!!! This isn't going to be a speedy build and will take some time to accumulate parts but hopefully I'll be able to keep a steady stream and get to know my UPS guy even better! :woot:
redefined
01-31-2014, 11:24 AM
Had to get the LQ in short block form for shipping. Should go out tomorrow and then I wait on my LS6 short block to show up!
I'll probably re-use the 317 heads, undecided if I'll have any machine work done on them. I'm getting a new set of LS6 springs with the short block, not sure if they'll hold up to what I'm building but most say they will! So possibly just springs and a custom cam is all I'll need to do to the valve train? Hmm
https://static1.pt-content.com/images/pt/2014/01/IMG_0215JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/01/IMG_0219JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/01/IMG_0222JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/01/IMG_0248JPG-1.jpg
https://static1.pt-content.com/images/pt/2014/01/IMG_0258JPG-1.jpg
Also need to decide on an intake. Currently I have a truck one which I need to toss up for sale. LS6 manifold and TB or FAST manifold and TB?
https://static1.pt-content.com/images/pt/2014/01/IMG_0263JPG-1.jpg
LQ water pump is so big. Probably toss it up for sale and get a vette one, should snug up closer to the block and look better. I'm so use to BMW water pumps, SO SMALL compared to this haha.
https://static1.pt-content.com/images/pt/2014/01/IMG_0262JPG-1.jpg
Jon @ Hotchkis
01-31-2014, 12:50 PM
Sure is a beautiful Camaro you have there. Did you happen to buy it from a guy on Lateral-g.net?
redefined
01-31-2014, 01:43 PM
Thanks, sure did!
redefined
02-12-2014, 11:55 AM
Shipped out the LQ block and due to the bad weather we've had the last few weeks down here I'm still waiting on the LS block to arrive.
After some long searching and reading on tune options and harnesses I've decided to go with PSI:
I've also sent Ricks Tanks an email regarding the specifics of the tank I'll need. Tubbed application that can support 750whp.
So while the snow and ice are here I'll continue to research and order parts! :evil:
