View Full Version : Brake hose on C5 conversion
69importkilla
01-28-2014, 04:50 PM
So I just did a C5 conversion on my 69. Is there any factory GM brake hoses that will work? I know the vette caliper is metric but what size is the hard line coming from the master.
Any suggestions?
Apogee
01-28-2014, 05:01 PM
Hard line should be 3/8-24 inverted flare, caliper is 10mm banjo...I'm sure there are OE hoses that could be made to work, but is there a reason you would prefer to rubber over reinforced braided stainless?
69importkilla
01-28-2014, 05:04 PM
No reason, just looking to tidy it up and get a "baseline"....
csouth
01-28-2014, 05:15 PM
Any suggestions?
Factory hose will not work because the hardline is standard on the car end. Kore3 sells hose kits that are correct for this swap, metric to standard.
http://www.kore3.com/products.php?cat=21
Mkelcy
01-28-2014, 07:57 PM
Silly me. On my '68 Camaro I used a braided stainless steel (Earls maybe) front brake hose set for a '68 Camaro and the 10mm banjo bolt for the caliper. Never had any issues with it. The rectangular banjo fitting on the brake line fit perfectly on the C5 caliper.
mciver1959
01-30-2014, 09:15 PM
I used the OEM C5 hoses with a small brass adapter from Napa to go from the late model bubble flair rubber hose, to the oringial Inverted flair hard lines
the napa number was WH1442
oreillys number is 271300
worked perfectly, and if anything fails, I can buy parts at any local parts store.
67cougnut
02-19-2026, 10:46 PM
Do you happen to have a photo of how you routed the factory soft lines on your car?
badazz81z28
02-25-2026, 07:21 AM
Why do you want an OEM hose?
Place like Crown can make you what ever you want in what ever configuration
JustJohn
02-25-2026, 10:57 AM
You can also call this guy: https://www.kore3.com/
