Slick68
01-28-2014, 07:27 AM
I'm throwing this out to get some ideas, opinions, and make a decision one way or another.
I currently have a carbureted LS1 in my 68 C10. The carbed setup utilizes an MSD ignition control box to fire the coil packs based off the cam sensor and crank sensors. I'm considering making a switch to EFI within a year or so. Most will tell me to just use a factory ECM/PCM and electronics, which I don't really have a problem with. It's most certainly a tried and true system with many benefits.
Here's what I want to know, though. MSD offers a harness (http://msdignition.com/product.aspx?id=4701&terms=6010) that allows use of an EFI system, but still allows timing controls without entering an ECM/PCM, which should allow the use of a stand alone fuel management system. The problem is I don't know enough about EFI and which system is best, and which one I should look into for doing this. Also, is there any major advantages of doing this over the factory EFI system?
