View Full Version : 69 nova...25 yr hiatus
dairdvl
01-27-2014, 04:31 PM
hey everyone. just wanted to post my build to see what you guys think. i found this forum which changed my whole outlook on this project.
This nova was the first car i ever bought when i was 17 in 1987 and have had it ever since. this project started to just get the car back on the road until i decided to go w/ the protouring route.
ill start off w/ a few old school pics first :twothumbs
https://static1.pt-content.com/images/pt/2014/01/DSC01899-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova%20-old%20pics/DSC01899.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/DSC01895-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova%20-old%20pics/DSC01895.jpg.html)
dairdvl
01-27-2014, 04:36 PM
off to the body guy for new rear quarters and primer
https://static1.pt-content.com/images/pt/2014/01/novatrailer2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/novatrailer2.jpg.html)
back from the body guy
https://static1.pt-content.com/images/pt/2014/01/IMG_2051-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/IMG_2051.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/IMG_2053-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/IMG_2053.jpg.html)
dairdvl
01-27-2014, 04:40 PM
fire wall and cowl painted
https://static1.pt-content.com/images/pt/2014/01/DSC01927-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/DSC01927.jpg.html)
motor and trans in
https://static1.pt-content.com/images/pt/2014/01/DSC01933-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/DSC01933.jpg.html)
motor wired and running
https://static1.pt-content.com/images/pt/2014/01/IMG_20131225_120946_4382-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/IMG_20131225_120946_4382.jpg.html)
dairdvl
01-27-2014, 04:46 PM
front suspension in from my good buddy Mark at SC&C and brakes from Tobin at Kore3. just finished this past weekend. trying to decide budget wise what to do with the rear :dunno:
https://static1.pt-content.com/images/pt/2014/01/DSC01942-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/DSC01942.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/DSC01943-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/DSC01943.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/spc1-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/spc1.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/spc2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/spc2.jpg.html)
dairdvl
01-27-2014, 04:50 PM
decided to go w/ these wheels. TSW Valencia rear-18x9.5 front 18x8. not sure on the tires yet but leaning toward Nitto 555 in a 235/40/18 front and 265/40/18 rear what do you guys think?
https://static1.pt-content.com/images/pt/2014/01/tsw-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/tsw.jpg.html)
craigs73
01-27-2014, 10:01 PM
you got two cheap options on brakes.... one is brakes from s-10(cant remember years) or ls1 brakes from 98-02 f-bodys
Zoomin
01-27-2014, 10:25 PM
Those brakes should throw you through the windshield compared to what it had! Very cool you kept the car that long too.
What color you going with?
dairdvl
01-28-2014, 03:58 AM
thinking of the original color which was Cortez silver or maybe something a little darker metallic silver
hookemdevils22
01-28-2014, 07:39 AM
LS1 F-body brakes are stupid easy to do, and they're almost identical to C5 rears, but with an integral parking brake. There's a write-up on this page (http://ls1tech.com/forums/17503418-post342.html) regarding the two setups, including how to modify the OE drum brake backing plates to save $$ on adapters.
For the wheels, I'm running TSW Tremblants in matte black. I went with a Ford bolt pattern, with 8" front and 9.5" (that I subsequently widened to 11") rear, 40mm offset each. The front has a 1" adapter, and the rears have .500" spacers with drilled axles/rotors. If you plan to run the 5x120 bolt pattern, I'd recommend running 20mm offset up front and 40mm out back. You'll likely need spacers for both, but I think those would fit. Here's the specs (http://ls1tech.com/forums/17712231-post271.html) (BS, offset, clearance, etc.) on my setup.
Edit: I believe the Corvette fronts push the wheels out 1/8" or so vs. OE discs? Keep that in mind. Also, I'm running 245s up front, 235s will give you slightly more clearance.
no go nova
01-28-2014, 07:41 AM
Nice ride and the ls1 brakes on the rear would be your best bet.
craigs73
01-28-2014, 08:52 AM
yep..... i got a complete set of ls brakes front and rear.... i even got used master and booster and e-brake handle from lstech
bs46488
01-28-2014, 11:56 AM
Nice work!
I vote 2 thumbs up on the wheels. I have a Gen 3 Nova. I triple checked my back spacing before I ordered my wheels.
dairdvl
01-28-2014, 03:56 PM
hookem
thanks for the info. you dont know how hard i have been trying to get some help on this. the wheels have got to be the hardest thing of this project yet.
do you have stock wheel wells? and what size rear tires are you running? did i miss that?
what suspension are you running in the rear?
my body guy was not too happy i think when i called him up about poss putting mini tubs in. i should have thought about that when he had it all apart.
craigs73
01-28-2014, 09:29 PM
i think you may be able to squeeze 275's out of it......but the fender lip would have to be rolled and have the right back spacing
hookemdevils22
01-29-2014, 08:31 AM
I have an Art Morrison ladder bar rear with coil-overs. I also did a home-brew mini-tub (http://ls1tech.com/forums/17449247-post332.html), thus the 11" wheels. Rears are 305/35-18... obviously don't use my setup as a baseline. The fronts, however, are 245/40-18, and I only have a little rub at full lock. That's with OE discs, tubular control arms, and QA1 coilovers sitting maybe 2" lower than stock. You'll be fine with 235s.
The 'here's the specs (http://ls1tech.com/forums/17712231-post271.html)' link I provided above outlines my methodology when choosing wheels. I had 15" Centerline Auto Drags on it before, which just kissed the outer fenders in the rear with 255/60-15 ET Streets. I calculated the forward space and created a schematic to show clearance, then aimed for at least 1/4" less forward space with the new rear wheels to give me clearance on the outside (I ended up with 1/2" less). I'd use your current wheels as a baseline, and try to see how much clearance you have on both sides.
sixgunsuperman99
01-29-2014, 09:03 AM
I just saw your introduction thread over in the Open Discussion part and commented over there... cool car! My 72 currently looks like yours did back in the day, and mine has been on a 20 year hiatus haha.
What are you running for springs/shocks? I just got done putting in the Stage 2 + upper and went with Hotchkis 1.5 inch springs and Koni's.
dairdvl
01-29-2014, 05:39 PM
six gun
i also have a stage 2 from SC&C. im good friends with Mark the owner. not sure on the springs. no shocks yet.
still debating what to do about the rear
Jon @ Hotchkis
01-31-2014, 03:55 PM
Hey Dairdvl, nice looking setup you have going so far.
I agree on the LS1 F-body rear brakes; the only thing to look out for is interference between the left caliper and shock. Since the Nova's have staggered shocks the left rear shock is very close to the caliper and will not work with the factory hose orientation on the caliper. If I remember correctly I took the hose on the caliper and rotated it 180* and ran the hose down and under the caliper and bent the hardline on the axle to meet it.
Let me know if you have any questions regarding the rear suspension or our products.
dairdvl
01-31-2014, 05:25 PM
this project is really snowballing since i decided to go the way i did.
got my wheels this week and they are just hitting the rear shock lower mounting point (no spacer. will post pics this weekend) and think im going to bite the bullet and go with updating the rear suspension. prob going to go with Chassisworks g link which i can get through my good friend Mark at SC&C.
what do you guys think....good choice or what?
Zoomin
01-31-2014, 06:16 PM
Man, I hear ya on the snowballing thing.
How did the rim look as far as clearance with the fender?
dairdvl
02-01-2014, 05:44 PM
the rear looks ok but close to the outside but def will not work with the stock shock location. not sure what to do. thinking of going with Chassisworks G-link.
the front will work just have to figure out what size spacer to use. picked up a spacer that was 1.25" which set me at around 5" back space i think and is too much. im pretty sure my wheel guy can make me some custom spacers prob around 3/4" i think.
dairdvl
03-02-2014, 12:35 PM
finally got the mini tubs done. what a project but i think the came out pretty good considering it was my first time.
https://static1.pt-content.com/images/pt/2014/03/tub3-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/tub3.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/tub2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/tub2.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/tubs5-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/tubs5.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/tubs4-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/tubs4.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/tubs3-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/tubs3.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/tubs2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/tubs2.jpg.html)
dairdvl
03-11-2014, 05:37 PM
got the tires on the new wheels and have to say i like them a lot. the tires barely fit and im thinking of narrowing the rear before i weld the brackets for the rear suspension. still got a lot of room with the new mini tubs. what do you guys think?
https://static1.pt-content.com/images/pt/2014/03/newtires1-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/newtires1.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/newtires3-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/newtires3.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/newtires8-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/newtires8.jpg.html)
https://static1.pt-content.com/images/pt/2014/03/newtires6-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/newtires6.jpg.html)
Razorhead
03-12-2014, 07:59 AM
Nice car ! What's your engine setup ? Looks cool with that air filter and so. Think of doing the same on mine one day.
dairdvl
03-12-2014, 02:19 PM
razor
nothing special. just a 350 sb with a cam and old school fuelly heads. prob around 350 hp. i got the 2 4's and intake from my Dad. just wanted to get her running and on the road. after that will start saving for something better :)
dairdvl
04-06-2014, 01:06 PM
finally got all my parts for the G-link suspension
https://static1.pt-content.com/images/pt/2014/04/rearsuspension2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/rearsuspension2.jpg.html)
cut off the old leafspring mounts ans started moch up for the mounts
https://static1.pt-content.com/images/pt/2014/04/rear-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/rear.jpg.html)
upper support
https://static1.pt-content.com/images/pt/2014/04/rearsuspension-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/rearsuspension.jpg.html)
i knew the frame was iffy but didnt know the pitting was that bad. so i decided to cut out the bad and weld in some new
https://static1.pt-content.com/images/pt/2014/04/rearframe2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/rearframe2.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/rearframe-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/rearframe.jpg.html)
dairdvl
05-03-2014, 02:29 PM
hey everyone.
rear suspension done. power steering done. working on the brakes and then waiting for the painter to get me in. cant wait to get some color tired of looking at the grey primer :)
https://static1.pt-content.com/images/pt/2014/05/rearsuspensiondone2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/rearsuspensiondone2.jpg.html)
https://static1.pt-content.com/images/pt/2014/05/rearsuspensiondone1-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/rearsuspensiondone1.jpg.html)
https://static1.pt-content.com/images/pt/2014/05/IMG_20140503_175822_0022-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/IMG_20140503_175822_0022.jpg.html)
https://static1.pt-content.com/images/pt/2014/05/IMG_20140503_175833_5602-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/IMG_20140503_175833_5602.jpg.html)
dairdvl
06-22-2014, 03:23 PM
well..after waiting forever she is finally off to paint. cant wait
https://static1.pt-content.com/images/pt/2014/06/2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/2.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/4-2.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/4.jpg.html)
here is the look im going for. any suggestions would be great
https://static1.pt-content.com/images/pt/2014/06/vipersilver-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/vipersilver.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/vipersilver2-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/vipersilver2.jpg.html)
dairdvl
08-24-2014, 04:19 PM
finally got her back from paint. i think it came out great.
now back to work
https://static1.pt-content.com/images/pt/2014/08/IMG_20140822_145108173_HDR-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/IMG_20140822_145108173_HDR.jpg.html)
https://static1.pt-content.com/images/pt/2014/08/IMG_20140822_145048477_HDR-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/IMG_20140822_145048477_HDR.jpg.html)
https://static1.pt-content.com/images/pt/2014/08/IMG_20140822_145025382_HDR-1.jpg (http://s254.photobucket.com/user/dairdvl/media/nova/IMG_20140822_145025382_HDR.jpg.html)
81sleepinOLDS
08-24-2014, 04:43 PM
It looks amazing!
Zoomin
08-24-2014, 05:22 PM
You got that back in two months? Amazing, it it looks fantastic too!
What did you decide about narrowing the rear end?
1965gp
08-24-2014, 06:40 PM
Love the color. I have those same tires on my GTO and TA and love them.
srh3trinity
08-24-2014, 07:51 PM
Those stripes are awesome!
dairdvl
08-25-2014, 02:06 AM
did not have the money to do the rear....yet :)
CruizinKev
08-25-2014, 02:29 AM
omg niiiice! love the color/stripe combo!!! :twothumbs
