View Full Version : alternator size
DButler
01-26-2014, 03:09 PM
OK so I am having problems when I drive my car and turn it off it will not restart. The holley HP will not fire with less then 12 volts. I have a yellow top optima battery. I currently have the holley HP ecu...electric black magic fan...areomotive a1000 pump...Msd...stereo...gauges etc. I can hook jumper cables to it and it will fire right up so I know its the alternator not charging or battery. When I am driving my gauge is showing 14 volts so either the battery isn't being charge or alternator isn't charging or isn't big enough...I keep a battery tender on the car. I think the alternator is 60-80 amp chrome one wire. May be a 100 but I am not sure. Should I go with a bigger alternator? Is it too small to keep the battery charged with all of my electronics? Any help is greatly appreciated.
ccmc
01-26-2014, 03:15 PM
What's your idle speed. You will spend a lot if time at idle and the higher amp alternators tend to charge less at idle. I had this same problem. Bought an overdrive pulley to spin the alternator a little faster and it's been running great for over a year
DButler
01-26-2014, 04:48 PM
When you say idle speed are you referring to rpm? If so it is 1000
Thephranc
01-26-2014, 05:31 PM
Are you sure its not a heat soaked starter?
DButler
01-26-2014, 05:43 PM
Yes pretty sure its not that because as soon as I hook the jumper cables up it will fire right up...the ecu requires a minimum voltage to start (either 12 or 12.5) gauge will show 12 when I turn key on but when I whirl it then it drops to 10 or below...when I M driving it shows 14 and when I park and turn off it want crank most time because voltage..bit gauge shows it charging so I think its either battery is not holding charge or alternator is not charging enough to keep the battery up
reschke18
01-26-2014, 11:34 PM
One wire alternators are notorious for not charging well at low rpms. You have to wing the throttle to get them to charge, or like stated earlier spin them faster. You will be far better off to wire it up with the normal three wires. You can most likely use that same alternator, just pull the block off plug out from where the alternator plug goes, and get a alt plug and wire it up.
astroracer
01-27-2014, 02:56 AM
X2 on that response. Wire the alternator as it came from the factory. ALSO make sure your wire sizes are more then adequate. Small gauge wire will cause resistance as it heats up and make the problem worse. I would wire all of your charging circuit with at least 8 gauge and would go as big as 4 gauge if the battery is in the back.
If the alternator is only a 60 or 70 amp unit you may concider upgrading to at least a hundred amp. It will be marginal at this point with "good" wiring so, if your wiring needs some attention, this would be the time to address the whole system.
Mark
DButler
01-27-2014, 08:24 AM
I am not sure how to wire it like original. I had a new painless wiring kit installed in the car a few years back. Also I never had this problem before. The last thing I have installed was a stereo. I have never had this problem before so I am wondering if the battery is just going bad and won't hold a charge it will fire right up when the battery tender is on it.
hessdawg
01-29-2014, 08:27 AM
I have had allot of problems with Optima yellow and red tops not holding a charge
I would take it to an auto parts store and have the battery and charging system tested
DButler
01-29-2014, 07:06 PM
What is a good batter to replace the optima? Anything that will fir in the optima battery bracket?
ol green
01-29-2014, 08:47 PM
With all the pull you have on your electrical system-fuel pump, amp, MSD, etc, when you add all that up and the lack of low rpm charging of the one wire, you need a bigger alt. Your elec fans can pull 50 amps and you only have an 80 amp alt to feed all this. I wire a lot of hot rods , the smallest alt I will put in anymore is a 140 amp. It makes life easier---my.02
DButler
01-30-2014, 05:16 AM
OK. Can you tell me what the first test to run to determine if battery or alternator. I would rather spend money in the right place to fix the problem. Should I take the battery and have it tested?
DButler
01-30-2014, 05:17 AM
My car did this when driving also cruising at 2500ish Rpms. I wasn't sitting idling.
ol green
01-30-2014, 09:09 AM
you bet, do the battery first, however the fact still remains on all the load you are putting on that alt..check how many amps all those electrical components need, you will be surprised for sure
DButler
01-30-2014, 11:33 AM
What a good 140 amp alternator? I really don't want to rewire car. It is SBC with march system
DButler
01-31-2014, 06:16 PM
Battery checked out to be good. So what is the next test?
TheJDMan
01-31-2014, 07:27 PM
You really need to read some of the electrical tech articles on Mad Electrical's site. There is a lot of good information on how the charging system is supposed to work. He also has an article comparing the single wire alt to the three wire. After reading his articles, I decided to convert my single wire alt to a three wire alt by changing the internal voltage regulator and running a dedicated sensor wire.
http://www.madelectrical.com/electrical-tech.shtml
dontlifttoshift
01-31-2014, 07:31 PM
It will not start or will not turn over?
DButler
01-31-2014, 07:53 PM
Great. I will read that info. It will turn over but just spins because the volley HP efi requires 12.5 Volts to crank and obviously the battery doesn't have that much because I can hook jumper cables to it and it will fire right up. When I turn switch on it shows 12-13 volts when I whirl it over it drops to 10ish and then when I'm driving it is charging at 14ish. I just had battery treated three times and it checks out good.
ol green
02-01-2014, 07:44 AM
contact March to find out what fits their brackets, the Mad Electrical as mentioned is a great site, lots of good info. as for alternators, Tuff stuff has quality US made parts, have had no problems with them at all
hifi875
02-01-2014, 08:36 AM
The Holley ecu must be ran directly to the battery. You need atleast a 140. And you want one that puts out atleast 90 at idle. Need atleast a 4 gauge charging wire and stater wire
hifi875
Powermaster alternators work great
DButler
02-01-2014, 01:50 PM
I have the ecu hot and ground connected directly to battery and also the a1000 fuel pump. I just put the battery in and cranked the car and it was charging at about 14.3. Then it was at 14. I hook battery tender up and it was at 95% and it was at 100%. Can you tell me how to wire for a three wire setup and also how to check to make sure I have 90 amps at idle? The car was firing right up this morning with no problem.
Nothingface5384
02-01-2014, 02:51 PM
odyssey or XSpower for battery if you need one
for alternator check out NewportStart N Charge
jamie mcclinton...11341 hwy 211...usk...wa...99180 or phone...509-447-0289 or [email protected]
he also does hi torque mini starters too
TheJDMan
02-01-2014, 04:13 PM
Already told you!!!! READ the MAD ELECTRICAL articles!!!! All the information you need and more is there.
astroracer
02-01-2014, 04:18 PM
http://madelectrical.com/electricaltech/onewire-threewire.shtml :)
reschke18
02-01-2014, 11:16 PM
I suggest you wire the alternator for 3 wires, and fix this issue, then you can check for the current at idle by using an amp clamp and a digital multimeter. The 90 amps at idle is a rating of what it is capable of supplying at idle. In your case it most likely will not put out this amount. It will only supply what it has to to meet the demands of the system. 90 amps would be if you had the stereo cranked past 11, the AC on high, all lights on, electric fans running, electric water pump on, and electric windows rolling, etc. Clamp around the wire on the back of the alternator and you can see the current at idle. I have had problems with Optima batteries as well. Once they are drained, they don't want to take a charge or hold a charge. My Optima would not hold a charge and unless I would turn on the lights to pull a load through the battery, it would not begin to accept a charge. I replaced it with an Interstate battery and have not had another starting/charging problem in over 6 years. If your problems are only on startup and not when its running, then the alternator is doing its job. It only supplies the power to keep everything operational while running and "sort of" charges the battery back to the level to restart the vehicle. I would put a good battery in the car and run with it!
