View Full Version : 68 - 69 Camaro 700r4 COMPLETE convertion
voice1000
01-25-2014, 08:22 AM
LOCAL PICK UP ONLY WILL NOT PACK AND SHIP. If Close enough will meet you half way.
After I install if you live in my area, Long Island New York these will be the parts for sale.
700R transmission rated to 450 hp and torque.
Lock-up converter with 1800 stall.
Speedometer Gear Set up for 3.08 rear.
Stainless steel cooler lines preformed
153 tooth heavy-duty flex plate.
153 tooth General Motors mini starter.
Inspection Cover Plate and Bolts.
Complete driveshaft.
Proper crossmember and transmission mount (not a modified original.)
(Price today 175.00)
Horseshoe shifter with proper detents for the shifter.
Shifter cable
All of the parts for the console. Cover where shifter goes through, all with proper labeling for the four-speed automatic.
Reverse light and neutral safety switch.
TV cable assembly made for fuel injection (you may need to change it for carburetor.)
Proper dipstick and tube (low hood)
Brake pedal (Disc Brake Pedal Pad Chrome Trimmed) (original)
Unit is perfect less than 5000 miles on transmission.
It's still in the car and you can get a chance to drive it and feel how it is before you buy it.
I also have Pressure gauge with 4 foot hose for setting the TV pressure properly on 700 R4 Transmission. $75 value Included.
Greg B 1969 Camaro convertible. $1500 total for everything.
[email protected] ([email protected])
