View Full Version : CR concern for running supercharger
78 Bird
01-24-2014, 09:14 AM
Hi guys I'm looking at getting the vortech v-2 supercharger kit to go on my 355 sbc. The engine puts out 375hp and 400ft/lbs of tourque with a 9.5:1 CR. My question is will that put my CR too high to the point that I can't run on 93 octane with my dart iron heads that are on the engine now? I've heard mixed results saying yea it would be too high and others that say it will be fine because the kit says it only puts out 6psi. Thought I should ask you guys to plan my costs. also if anybody knows where to get a good blow through carb for the application let me know. Thanks guys, Ray
705.0Merc
01-25-2014, 09:01 AM
You will be fine on 6lbs with 93 octane. It is all in a safe tune. Proper airfuel ratio curve, timing and spark plugs. For comparison, I have a 302 with 9:1 ish on 91 octane. I am running 9 psi with a turbo and intercooler. I built my own carb for blowthrough from these (http://www.hangar18fabrication.com/blowthru.html) directions. For a carb and company called CSU (http://www.csucarbs.com/) is really good. Check here (http://www.theturboforums.com/forum.php) for really good forced induction info.
78 Bird
01-25-2014, 01:30 PM
alright thanks a lot, I'll check all that out!
