View Full Version : Newbie from Columbus Ohio
Wardracing
01-22-2014, 10:28 AM
Hey guys, my name is Travis, I'm 22 years old and have a 1970 Camaro.
It is build for Autocross and road racing, it sees some street miles as well.
Have not had a chance to go last year, so hopefully this year I can get some seat time.
Racing has always been a part of my life since I was a little kid watching my dad race Super Vee's & Formula Atlantic.
Have been racing karts since I was a kid and still do, and have done some open wheel racing.
https://static1.pt-content.com/images/pt/2014/01/photo6-1.jpg (http://s1139.photobucket.com/user/wardracing/media/photo6.jpg.html)
https://static1.pt-content.com/images/pt/2014/01/photo2-1.jpg (http://s1139.photobucket.com/user/wardracing/media/photo-2.jpg.html)
BMR Sales
01-24-2014, 06:22 AM
Very Nice Travis! Did your Dad race Atlantics Nationally or Regionally - I might have against him.
Welcome to the Site!
T.C.
Wardracing
01-24-2014, 08:55 AM
T.C.
He raced nationally.
Name is James ( Jim ) Ward, Wardracing Team.
He had a White & Blue Popeyes chicken car, and a Dark Brown Black Duraflame car, those are the only cars i can remember.
LUV2XLR8
01-24-2014, 09:19 AM
welcome!... glad to see another northerner joining the group... From ERIE my self.
Feel free to start a thread about what you've done to your Camaro... upgrades/performance mods/ect.
-Ben
Wardracing
01-25-2014, 12:09 AM
So it is a 1970 Camaro unfortunatly I do not have a build sheet, other wise I would now the trim code.
But it is badged as an Z28. Engine is a 1 piece rear main 383 SBC crate motor from Blueprint engines.
210 intake runner aluminum heads. about 480’s cam can’t remember. 320 whp 360 lbs/tq currently 100 shot 360 whp 400 lbs/tq
Edelbrock air gap intake, Holley 750 ultra hp, msd billet dizzy with mad 6al box.
Becool 3 row radiator, Aluminum high flow water pump.
long tube headers straight pipe 2.5 mandrel bent exit before tires.
Lt1 T56, Aluminum drive shaft shop, Dana 60 rear end that has been shortened Moser axles Ford 9 inch axle bearings with 3.73 rear gear.
Spec stage 3+ clutch, mechanical linkage use mucie 4 speed bell housing and clutch, adapter plate to fit T56.
12.7 power steering box, high flow steering pump. tubular control arms with delrin bushings and additional caster over factory, moog tie rods center drag link etc. Adjustable upper A arms & tall ball joint, AFCO single adjustable front coil over conversion. Solid Aluminum 1/2 inch lowering body bushings. Chasis Works sub frame connectors. Composite rear leaf springs with front and rear delrin bushings. Custom 3/4 inch front leaf spring bracket. lowering shackles with upper delrin bushing. Axle pad locator, double adjustable AFCO rear shocks. 275 tires all the way around. C6 13 inch Wilwood front brakes 3 inch brake cooler, manual master cylinder, 11inch Wilwood D52 rear brakes. Front G-Braces connects form upper A arm to cowl area and fender bolts create triangle. Adjustable front and rear solid sway bars. Front sway bar brace. No rubber No poly bushings. car right now weighs 3500 in it, have switched to Corbeau fiberglass seats, fiberglass 2 inch cowl and 50 pound weight losing on the composite leaf spring. and will make some more changes for weight, hope fully get it down too 3200-3300 lbs with me in it
Munssey
01-25-2014, 08:03 AM
Welcome aboard! Love the Camaros.
deejai35
01-25-2014, 05:23 PM
Very nice Camaro! Welcome to the site. I am in Columbus too.
