View Full Version : UMI Releases New Product- Roto-Joint Rear End Housing Bushings for 65-88 GM A/G-Body
UMI Performance
01-21-2014, 07:48 AM
Roto-Joint Rear End Housing Bushings for the 65-88 GM A/G-Body
P/N 2999 priced at $129.99/set
UMI Performance, Inc is proud to introduce our P/N 2999 GM A/G body axle housing Roto-joint. The 2999 allows full articulation of the GM 4-link rear suspension. By using 2999 and either Roto-Joints or rod ends in the other six locations, your 4-link will move bind-free. Whether it be autocross transition, road race cornering or just back road corner carving UMI has you covered. For street use, they also pair well with our hybrid poly/Roto combination arms - poly for comfort and Roto-Joint for performance. These Roto-Joints install with a gentle press fit and are retained by an easy to install spiral retaining ring. The 6061-T6 aluminum housing is pre-greased with Synco Super Lube and will provide smooth motion for years to come. 100% manufactured in Philipsburg, PA-USA.
>Website Link Here< (http://umiperformance.com/catalog/index.php?main_page=product_info&cPath=1_18_19&products_id=779)
https://static1.pt-content.com/images/pt/2013/12/2999a_LRG-1.jpg
dontlifttoshift
01-21-2014, 08:17 AM
Those are neat, how about the same thing for the diff side of an S197 UCA?
Rick Dorion
01-27-2014, 04:13 AM
Will those fit into the rear arms you offer for the 65-70 B-body?
