silvermonte
01-12-2014, 03:33 PM
I notched the frame on my 80s cutlass to allow for some wider tires. While I was at it I braced up all the weaker points in the frame and also boxed in all the open areas. The area that I worried the most about was over the rear axle. I took out a fairly large chunk of metal when I did the notch and wanted to brace it up to minimize frame flex. I did not have the axle in when I put in the pipe for the bracing and at the time I thought I had plenty of room for suspension movement. After putting the axle back in I have alot less then what I think I need and will have to redo my work.
I have 2.5" of clearance till the upper arms hit the pipes. In the very near future I will be swapping to coil overs and I want my car to sit as low as I can reasonably get it. My thought is when the lower arms are level is probably the best. So my question is how much movement will the axle have with coilovers, and with the current coil spring set up. Im not looking for an exact number but just a general number so I can make adjustments right now.
https://static1.pt-content.com/images/pt/2014/01/001_zps79e203bb-1.jpg (http://s213.photobucket.com/user/silvermonte/media/001_zps79e203bb.jpg.html)
When I put the pipes in I figured this was a good set up to brace the frame from flex. I do not have a degree or anything close to having any real knowledge of the subject. Since I will be redoing it I would like some opinions on what I should do to better brace it. After the coilovers are installed, and way down the road I may put in a watts link, but that will depend on budget and if there is a need for it.
https://static1.pt-content.com/images/pt/2014/01/005_zps82201884-1.jpg (http://s213.photobucket.com/user/silvermonte/media/005_zps82201884.jpg.html)
