View Full Version : Frame Package
Smittys
01-10-2014, 10:04 AM
Guys we are going tooffer rolling frame package.
67-72 Chevy GMC shortbed Frame package $10975.00
Complete Frameincudes
1 No-Limit wide ride front suspension package with WilwoodBrake calipers Ridetech Coilovers
2 No-Limit Fat Bar 4-link rear suspension with RidetechCoilovers
3 No-Limit Rear Rail kit raises floor 4 inches
4 9 inch Housing and axles
5 Wilwood 12 inch D-52 rear disc brakes
6 Fully assembled and painted Black
7 Tranny cross member
Options available
Air Ride
No-Limit Aluminum fuel tank
Shock upgrades
Splined Sway bar
Line kit installed
Frame boxing
Tubular center supports with tranny mount
Brake Upgrades
Rake upgrade
9 inch center sections
Roll cage kits
Bed and sheet metal packages.
88422
Guyt699
01-10-2014, 11:58 AM
Man! That is bad ass!
1truckguy78
01-10-2014, 10:05 PM
That's very cool.
joesbruiser
01-11-2014, 07:24 AM
I see in your list of options you are going to offer roll cage kits. What will the kit consist of and could the legs be cut down to work in my sons chopped top with the laid back A-pillars? Also do you have any cost estimates yet?
I am weighing taking the truck to a chassis shop,buying another bender and notcher and doing it myself or trying to find a kit.
Thanks Joe
Smittys
01-11-2014, 09:01 AM
Joe we have patterns off what we did with my truck. I have a cab I am working on a couple options. You could bring the truck up and we could build it. Cost will vary on material and amount of cage. I'm working on all that stuff as well.
88484884858848688487
joesbruiser
01-11-2014, 11:02 AM
Thanks for the reply. I know pricing varies and i am not trying to get a number set in stone,but to do the same basic layout of your truck in 1.75 mild steel what would the ball bark be?
Slick68
01-12-2014, 03:57 PM
What about building just a harness bar for the guys that don't want/need a full cage?
Smittys
01-13-2014, 12:20 PM
Matt im not sure what you want this bar to look like but I can do it pm or call me.
Slick68
01-13-2014, 12:51 PM
Kinda like the one in this article.
http://www.classictrucks.com/tech/1302clt_corbeau_race_seat/
Smittys
01-13-2014, 01:17 PM
Yes I could build that bar and legs. Moly or steel.
Slick68
01-14-2014, 04:41 AM
Whatever you think would be better. Seeing as it's holding my fat butt in place, steel would probably work just fine. What will something like that cost?
Smittys
01-14-2014, 09:46 AM
Matt can you weld the down legs on yourself? I am looking at making this a option it will be $550-$600. The big issue is the seat height for the harness bar. They might have to be built to order.
csouth
01-14-2014, 12:28 PM
Whenever I see one of these truck at and event, you make me want a C10...
Slick68
01-14-2014, 12:38 PM
I don't personally have a welder, but I know a few people that could weld it down for me. I figure these may need to be custom built per order. I know for a fact there's no way to fit one with the bench seat, but there's room with racing style buckets. If I go with buckets, I'll probably run the Corbeau Forza II fixed back seats.
Smittys
01-15-2014, 05:47 AM
You will need the seat mounted on the risers and take some measurements.
Slick68
01-15-2014, 10:14 AM
Any recommendations on risers that work well in our trucks?
Smittys
01-15-2014, 12:55 PM
You can fix mount them or put them on sliders either way I always make them ( riser ) so you can adjust them for your comfort.
LS2-C10
01-15-2014, 05:44 PM
Sounds like an excellent plan!
Slick68
01-16-2014, 01:16 PM
What about these?
http://jasonlangdon.com/seatrisers/
