View Full Version : MOSER Aluminum 3rd Member - Part # 3062ALU - Through-Bolt Aluminum Case - NEW!!!
g-machine
01-03-2014, 10:55 AM
Purchased from a member here 3-4 months ago, this is brand new in the box (box has shelf wear). I need to focus more on other areas of the car at this time. This is a great deal!
Taken from the manufacturer website:
PRODUCT DESCRIPTION
Moser Aluminum Cases are made of 206-T4 aluminum with 7075-T6 aluminum caps and billet steel adjusters. Features a super strong through-bolt design to give the case increased strength and decreased ring gear deflection common in most aluminum case designs. All Moser Aluminum cases are drilled for the 3/8 stock pinion studs and 7/16 heavy-duty studs. The aluminum cases are also designed to be used with either a standard pilot bearing with snap ring retention, or a heavy duty, wider pinion bearing utilizing button head bolts for retention is available. Moser Aluminum Performance Cases weigh only 16 lbs., 15 lbs. lighter than our Nodular Iron Cases. All Cases are CMM checked for machining accuracy, and are supplied with all Grade 8 hardware. Made in the USA!
SOLD!!!
Please email me with any questions: [email protected]
g-machine
01-05-2014, 09:56 AM
Sold!!!
g-machine
01-06-2014, 08:48 AM
:firefire:
cwylie
01-06-2014, 09:27 AM
That part looks familiar! ;-)
g-machine
01-06-2014, 10:21 AM
:lol: yeah, selling some items I don't at this time........clearing up debt and starting the year fresh!
