View Full Version : Second gen camaro 305s all the way around?
71maroesteban
12-29-2013, 06:49 PM
Is it possible I was thinking about putting some fender flares and seeing if I couldn't fit some 305s all the way around?
badazz81z28
12-29-2013, 07:09 PM
On a stock suspension, 275s on all four corners would be the MAX. You really can't get anything bigger than 285/295 on the back without pounding or rubbing. The front will rub the sway bar on turns.
71maroesteban
12-29-2013, 07:15 PM
On a stock suspension, 275s on all four corners would be the MAX. You really can't get anything bigger than 285/295 on the back without pounding or rubbing. The front will rub the sway bar on turns. what about with fender flares and running some rims that hold it farther out? Kinda like the spectre Camaro?
badazz81z28
12-29-2013, 07:55 PM
Oh yeah, if you wanted to do that to the body of the car. It would be no different than installing mini tubs. I personally don't like the look. Have you considered Mini tub or aftermarket subframe?
71maroesteban
12-29-2013, 08:21 PM
Oh yeah, if you wanted to do that to the body of the car. It would be no different than installing mini tubs. I personally don't like the look. Have you considered Mini tub or aftermarket subframe?[/QUOTE] I have and both are way out of my price range a mini tub kit is upwards of 2 grands after its all set and done I have a good stock subframe so I don't want to have to add to my expenses and buy another I can get flares like the ones on spectre s Camaro for under a grand installed all I guess I'd have to do is get some huge wheel and tire combo to fill them out and like maybe a 2 backspacing? I'm not to good with fitting wheels or tires it's something I've overlooked to much and never even looked into
