View Full Version : where to start with my new american wire kit
cali-life
12-26-2013, 04:35 PM
hey guys need a lil help i just received the american auto wire update harness kit but dont know where to start on it.
what do you guys recommend its for a 68 firebird. Should i start in the engine compartment or back inside dont know i want to do it right the first time and a clean job any thread or helpwith this would be great
Z06vet
12-26-2013, 06:08 PM
I've done 4 or 5 of these in fist gens. Directions say to start at the back of the car, but I prefer to mount the fuse box first and work my way out from there. I do under the dash first, then move toward the back. When all that is done i move under the hood. Just my perference. I also don't care for using the connectors/plugs for the taillight sockets. I just dont see the need for them as they are easily accessible. And they fit nicely in the wireloom without the connectors. You'll find there are several wires not used in different parts of the harness. If youre unsure about any of them, just zip tie or tape them into a bundle until you are finished. You can remove any uneeded wiring from the bulkhead if you wish. I typically make a tight coil of the unused underhood wires, zip tie the bundle, then tuck them in the cavity of the innder fender below the bulkhead. Just in case...
Scott
raustinss
12-26-2013, 06:51 PM
2nd that
Classic Nova & Performance
12-27-2013, 03:30 PM
We do much the same as was specified above. I locate the fuse block and then group the wires based on their location. Meaning separate all the rear body wires, front harness, engine compartment, dash section. From there you can work on which ever section you want first. I like to complete a full section before I move to another.
MuscleRodz
12-27-2013, 09:55 PM
follow the instruction if your unsure of anything. Like the other stated, I start with mounting the fuse panel then start at the rear and move forward doing the engine and front light harnesses last
Jim Nilsen
12-28-2013, 06:53 AM
I'll make it unanimous, start with the fuse block and go from there. it should be easy enough to just go in one direction at a time and 8 hrs later or less and you should be done.
MuscleRodz
12-28-2013, 08:08 AM
I'll make it unanimous, start with the fuse block and go from there. it should be easy enough to just go in one direction at a time and 8 hrs later or less and you should be done.time will vary greatly on how much extra goodies he has like power windows, locks, fans, etc.
cali-life
12-30-2013, 02:34 PM
thanx guys i was going to start at the engine first then head back. oh good ...one more question do i take the old wiring out first or as i go??????????
Z06vet
12-31-2013, 05:39 AM
I would take it all out first. It may help you to lay all the old wiring on the ground in the configuration it was in the car. You can refer back to it for guidance if needed.
cali-life
01-03-2014, 09:54 AM
i want to hide the wire in the engine bay. where have you guys run the wire threw?
cali-life
01-03-2014, 10:07 AM
or pix of and engine bay all cleaned up would help
classiccarcustoms
01-04-2014, 09:46 PM
Love American Wire harness.
Here is one installed on my 65 SS.
Same as above, I started with fuse box, moved to tail lights, then engine bay.
Hope the pictures help.
