View Full Version : 69 camaro sub frame connectors
dragonfly jones
12-22-2013, 10:57 AM
Do I need the motor in the car when I install them , or do i just need to load the suspension?
77thor
12-22-2013, 11:22 AM
It is recommended that the car be completed(motor in car), as in fully loaded suspension.
If you can compensate for the missing engine by adding the same weight, you're probably OK.
dragonfly jones
12-22-2013, 12:03 PM
Thanks Fred
TheJDMan
01-10-2014, 06:48 PM
What subframe connectors are you installing? Bolt in or weld in? If weld in you would be better off waiting till you have the engine and trans installed.
1967c10
01-20-2014, 05:42 PM
Is this necessary if your going to use solid interlock bushings?
