View Full Version : C6 Grand-Sport Corvette front brake calipers and pins
jeremy30thz
12-21-2013, 08:47 PM
Item Location (City/State):Greenwood SC
Price: $550
Description: C6 Grand-Sport Corvette front brake calipers and pins. Same as Z06 just silver instead of red
Samckitt
12-22-2013, 05:59 AM
@%^&*() dangit, if only it wasn't 3 days for Christmas.
vette4beater
12-22-2013, 06:46 AM
Is there an easy way to make these work on a 66-67 GTO??
I had drum brakes, now have aerospace engineering 12" 4 Piston set-up (just like Wilwood). but they look kinda small in my rims.
I'd have to sell my current brakes to my brother to get these if they would not be too expensive to get everything else
raustinss
12-22-2013, 07:25 AM
Vette4beater yes they will fit once you change your spindle to what's called a AFX spindle. It's a aftermarket spindle that uses a corvette hub allowing you to use any corvette braking system. I'm doing the same thing with my 70. If you choose this route get corvette ZR1 hubs as I'm told they last a little longer then "normal" Vette hubs. Good luck Jeremy is a good guy
Ryan Austin
csouth
12-22-2013, 07:40 AM
Although they are nice pieces, you don't need AFX spindles to use these brakes. KORE3 sells the brackets to mount these to stock GM short and tall spindles. Call Tobin, he'd be glad to set you up. He's also frequently in the brake forum user name "Apogee"
http://www.kore3.com/proddetail.php?prod=10083-01
badazz81z28
12-22-2013, 08:58 AM
Man I wish I waited! IMHO I don't think these would work well with the GMTS since these calipers are not floating. Don't get me wrong I would still use these. I have the kore3 solid spacers
raustinss
12-22-2013, 03:42 PM
Csouth you are 100% correct... I had a total brain fart yes of course Tobin has those parts for him. Terrible when I'm using his stuff for my rear end with Z06 brakes
Ryan Austin
jeremy30thz
12-25-2013, 09:27 PM
Sold
